Noisy Fuel Pump!!!
My fuel pump sounds rough as fook at the mo on tick over kind of a real loud "Buzzing"???
As fuel gets lower it gets louder and louder until i top up!
Would a dodgy pump make much difference performance wise?
Nick
Nick
you might not have a knackerd pump it might just be thatthe fuel pump noise dampening rubbers are knackerd and the pump is vibrating of the inside of the mounting bracket mounted to the floor.
i am pretty sure its a problem with the pump and not its mounting brackets because it really whines when it is low on fuel so much that it embarasses me.
A noisy pump should not make much difference performance wise m8, my pump starts getting real noisy when am low on fuel just above the red so I try and keep it above the quarter tank all the time! A pump off an xr3i or 1.6i orion is the same if it gets too noisy
To be honest ive just had a new pump and its fine just a small amout of buzzing which i think is normal but you should expect it to be louder when really low on fuel as i think all pumps to this
a noisey pump, theres gotta be something wrong with it, its proberly tired anyway if been on there from new,
as said before, a good fuel pump on a rst is critical for fueling, as the years goes by the pump loses its smoothness of the flow, leading to lean fueling and a blown up engine, so u might aswell replace it anyway for a piece of mind
Too the lads that replaced their fuel pumps..................Did you just buy a standard pump from youre local friendly Ford DEALER or buy an aftermarket uprated one????Regards Micky
JK12
33
26-04-2021 12:09 PM
155lee
24-10-2015 11:11 AM
wheelwizardrefurbs
23-09-2015 09:21 PM
