Fuel relay issue
Old Jul 26, 2025 | 11:30 AM
Gturbo's Avatar
Gturbo
Default Fuel relay issue
Hi guys
Done plenty searching on this. It’s great how many years you can go back on this forum! However, can’t find an answer to my problem.
Fuel pump doesn’t prime on ignition, nor does it kick in when the starter is turning.
Bridge the pins on the relay, or open the relay and manually operate the relay and the car fires and runs without issue.
Pump replaced
Fuel filter is new
Relay is new and a genuine Ford part
I can only think that whatever is telling the relay the ignition is on isn’t doing so as everything else is working? Could be wrong but I’m thinking this is the green and red wire in the centre of the relay on pin 1 however I’ve no idea where this goes to.
any advice much appreciated!
Old Jul 26, 2025 | 11:57 AM
GVK.'s Avatar
GVK.
There's a poster on here OAP Pete, he's 80 bless him but an oracle for RS turbo electrical knowledge, hopefully he'll see this post.
Old Jul 26, 2025 | 12:13 PM
Gturbo's Avatar
Gturbo
Sorted already haha!
Turns out pins 15 and 31 needed swapped. Priming and firing perfect now!!
Old Jul 26, 2025 | 12:14 PM
Gturbo's Avatar
Gturbo
And meant to say, been reading loads of OAP Pete’s posts/replies the past fortnight while I’ve been trying to work this out. His knowledge is unbelievable.
Old Jul 26, 2025 | 03:20 PM
OAP Pete's Avatar
OAP Pete
Good you got it sorted....im 82 now....yes the "green & red" is " 1 " on the relay and comes from ignition coil pulse and rev- counter.......Pete
classic1275cc
Dec 17, 2019 07:41 AM
E83w vince
Nov 23, 2018 05:08 AM
rosie
Oct 2, 2010 10:15 AM
Hrsturbo
Feb 26, 2006 12:52 PM
kurdt5
Oct 25, 2005 08:23 PM
