what triggers fuel pump relay 2 prime???
my rs turbo wouldnt start when warm & ive narrowed it down to the relay not primeing/pumping.
i bridged the relay & it runs everytime
i fitted a new relay but the original problem was back
i have bridged the relay again & its fine so it isnt the relay itself its whateva tells the relay 2 work??????
is this the fuel ecu or is there a sensor on metering unit etc......??????
It primes on ignition then pumps when it sees tacho pulses from the negative side of the coil. The relay also has a crank signal so it knows when the engine is being cranked over.
mine has ignition feed as it is bridged off that atm
maybe ill have a play & try change fuel ecu & see what that does as im getting nothing when warm, no pump on ignition or crank
JK12
33
26-04-2021 12:09 PM
DixieTheKid
11
06-06-2020 11:20 AM
