S2 management
bought a s2 that’s on cosworth management it’s still running the dizzy what’s needed to change to coil pack?
Also I have a ofam boost moneys Ecu am I right in saying Il have to change the loom to run this on the s2?
Coil pack, wasted spark driver in the ecu, probably also need a wasted spark sub loom and a additional ignition amplifier. Then a mod to the rev counter. Or you may be able to use a P8 ecu but I can't remember tbh. Motorsport developments would be your people to speak to.
Ofam would need engine loom from a frst or a efi escort with some pin changes iirc. A lot of people want them OFAM ecu's you should have no trouble selling it if you choose to.
I had nothing but trouble with cossie management. Personally I would go for a more modern system. A modern system will have all the extra buts out the box like coil pack, closed look fueling and boost control etc etc.
Stu @ M Developments
16-10-2006 03:06 PM
