Garage / Workshop & Tools Section. Given working on your pride and joy is often one of the reasons cited for owning a Ford, post all your garage and tool collection pictures and questions in here.
Coil pack
Old Dec 29, 2017 | 10:50 PM
kyam786's Avatar
kyam786
S1 RST LUV
Default Coil pack
Hi need help with a coil pack problem is i bought an zvh engine and it's got an coil pack on it instead of distributor and iv got a l6 management with no coil pack plug how do I solve that problem I want to stick with coil pack it's a efi
Old Dec 30, 2017 | 08:58 AM
Caddyshack's Avatar
Caddyshack
I would talk to MSD as I am sure they can do a driver, if they cant then I doubt it can be done. Stu is a moderator on here
Old Dec 30, 2017 | 08:59 AM
Caddyshack's Avatar
Caddyshack
http://www.motorsport-developments.co.uk
Old Dec 30, 2017 | 11:21 AM
costina's Avatar
costina
Live long and prosper!!
Do you have the cossie loom? If so you will need a wasted spark sub loom about 60 quid. Has your level 6 been converted to wasted spark? If not thats the cost on the MSD site.
Then it will require a map.
Cheaper way is rs turbo ofab ecu loom and associated parts edis 4 etc.
Hope this helps
Old Dec 30, 2017 | 04:03 PM
martysmartie's Avatar
martysmartie
This is correct, MSD can install/supply a driver for the ECU. You also require twin ignition amps.
Martin
IANS2RST
43
Sep 15, 2007 06:21 PM
GUZZLER
15
Jul 27, 2007 08:19 PM
alan rainbow
Jun 8, 2005 03:28 PM
ImaRacing 700
40
May 4, 2005 10:55 PM
Roosie
Aug 16, 2004 11:14 AM
