what coil to use on coil pack conversion
as above, at the moment my car is still running twin coil on plugs, i want to change to a single coil, i know Rainbird does the leads to fit the YBP head but what coilpack is used on the cosworth???
Does ayone have the Ford finnis number or what Ford its off.
thanks in advance.
thanks in advance.
Testing the future
you can't change to a single coil unless you then use a distributor - the coil pack is still 2 coils that fire to 2 cylinders at once so what's the point to change?
Originally Posted by GUZZLER
Cheers Euan, does yours have the leads that 'clip' on the coilpack or just push on?
My old leads were converted to run with the coil pack.
normally cosworths are changed to coilpack to lose the distributor
the point to change to change is that the coil on plug packs get very hot & become unreliable with big power, there also expensive to replace, a sigle coil located out of the cylinder head will keep a lot cooler, work better, last longer & if it does need to be replaced its a sight cheaper
Testing the future
i know that the YBP does not have a dizzy matt, that's why i said that if you went to a single coil (not the twin coilpack) you would need to use a dizzy
it was a slightly facetious way of pointing out that the coilpack is still a twin coil, not a single coil as you asked about. but that's just me being a pedantic twat
i appreciate that having a coilpack positioned elsewhere could be more reliable, but i just prefer the simplicity of the coils on the plugs
I use the eecIV coils with no problems
they have never given me problems at 2 bar boost
and i think they're just as reliable if not more
there's no external plug leads to break down/get wet
and they can be bought very cheap, they're same as granada ones
i got offered a new set for £75 each, i'd rather convert to a single coil though.
mk3ste
17-10-2021 10:09 AM
07-10-2015 12:56 PM
