Wheel bearing again...
Old 09-06-2018, 10:54 AM
Carlitos
Carlitos's Avatar
Default Wheel bearing again...
Had the car up the other day and noticed the wheel bearings are a bit wobbly. I had them done after I bought the car, so just under 1.5 years ago and probably only a few thousand miles since. Surely wearing too soon? Any idea if this indicates a worn hub or something else?
Old 09-06-2018, 12:26 PM
Caddyshack
Caddyshack's Avatar
Can they not be nipped up tight?
Old 09-06-2018, 02:05 PM
Carlitos
Carlitos's Avatar
Did that once on the passenger side. Loose again, although not as loose as before. I suppose the garage who did it may not have pressed the bearings in all the way.
Old 09-06-2018, 02:49 PM
timsrs
timsrs's Avatar
Did you use cheap bearings
Had a cheap set on mine in the past only lasted a year
Get a decent make SKF
Old 09-06-2018, 03:29 PM
Rusty85
Rusty85's Avatar
If they tighten up and are smooth and quiet then not being fully home when installed is possible and they might survive. You will know when they have started to break up by the noise or MOT failure.
Old 09-06-2018, 09:12 PM
Carlitos
Carlitos's Avatar
Thank you both for your replies. I took a look earlier and tightened both front ones up a bit. They still were smooth without noticeable sound so hopefully the bearings themselves are ok. MOT is due in 1 month so I guess I'll find out then for sure.
Bit annoying having to steak/punch the nut. The only bearings I've done myself were on Mercedes which have a nicely designed lock nut, I wonder if anything like that is available for these cars.
Old 12-06-2018, 12:21 PM
cabrst
cabrst's Avatar
front bearings have to be tigthen @ 235Nm acording to Ford spec.
but the hub flanges are know to be worn..
Shaunc
Escort Range
27-10-2016 03:29 PM
herbie
28-11-2009 03:55 PM
pete mcrash
61
21-05-2008 08:56 PM
RS500/364
34
16-03-2005 10:55 AM
Quick Reply: Wheel bearing again...
