zetec turbo idling issue
Old 02-05-2015, 04:17 PM
Cameron
Cameron's Avatar
Default zetec turbo idling issue
Just wondering if any one can help me here, ive been running a 2.1zvh for about 3 years on OFAB with suitable chip, i've just converted to zetec again 2.1 with the same injectors, turbo, manifolds etc and the thing just idles at about 2000rpm, i cant find any air leaks and i've also cleaned the ISCV out which hasnt changed a thing, any ideas?
Old 05-05-2015, 12:08 PM
Karlos G
Balls Deep!
Karlos G's Avatar
If you are on the same chip you really need a remap or Zetec turbo chip, the Zetec head and CVH head flow quite differently.
But just to bring your idle down try unplugging your ICV and set the idle around 600rpm (hot) using the throttle stop (you don't say what TB you have but I'm assuming it has adjustment).
Old 06-05-2015, 09:07 PM
Cameron
Cameron's Avatar
Thanks for the reply Karlos, i've unplugged the ICV and it does idle quite low but mantains idle speed, i've actually got an OFAM ecu, Rob has put a basemap on it for me i wonder if its worth fitting that to see if it makes a difference? You map these dont you? its a fiesta turbo throttle body
Old 07-05-2015, 06:26 PM
Karlos G
Balls Deep!
Karlos G's Avatar
The base map may have an unstable idle for other reasons (ie. needing a proper mapping session) but you could try it.
I do mate yes.
Old 07-05-2015, 07:53 PM
Cameron
Cameron's Avatar
Thanks i've just sent you a message on your facebook page actually, i'll call you tomorrow if its convenient
robnock
21
13-05-2019 05:29 PM
Chopshop85
17-08-2015 06:38 PM
turbobill
09-08-2015 05:21 PM
Cameron
14
09-08-2015 06:28 AM
turbobill
01-08-2015 08:55 PM
Quick Reply: zetec turbo idling issue
