Delayed starting !!
Old May 6, 2004 | 03:04 PM
220TC's Avatar
220TC
Default Delayed starting !!
Hi,
Today when I went to start my car (S2 erst) I turned the key and nothing happened for nearly 10 seconds !!!!! It then started as usual, what could be causing this delay ?
Cheers, Duncan
Old May 6, 2004 | 03:07 PM
EvansS2's Avatar
EvansS2
Mine does it mate, sometimes fires on first crank like, but say go to shop only a short journey, jump in car 10-15 secs or cranking before it goes. God knows why it does i,t taken it to a garage and they dont know why either
Old May 6, 2004 | 03:34 PM
JesseT's Avatar
JesseT
I had a similar problem (not even cranking happened for a couple of seconds). It was cured by runnning the "signal" to the starter through a relay. Not enough voltage was reaching the solenoid of the starter.
Old May 6, 2004 | 05:44 PM
220TC's Avatar
220TC
guys, mine dosen't even crank, its just silent anyone else any ideas as to why it might be doing this ?
Duncan
Old May 6, 2004 | 05:52 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
if u had it out, starter may be getting too hot and ju snot responding cos of the heat. try some sort of heat shield or exhaust wrap???
Old May 6, 2004 | 08:26 PM
Exeter J's Avatar
Exeter J
This was my first thoughts - lazy /overheated starter or even slightly low battery
Old May 7, 2004 | 08:28 AM
bigal1978's Avatar
bigal1978
220t is this the first time its done it ?
Old May 7, 2004 | 10:26 AM
220TC's Avatar
220TC
yeah its the first time it delayed for such a long time, it has done it before a few times but there was only about 2-3 seconds gap between turning the key and the car cranking. I think it only happens when the car is cold or has been left for a little while, when its hot its usually fine.
I wouldn't of thought it was the starter, its not as if it cranks for ages and then starts, it fires up almost instantly.............after the pause !!
any ideas ?
Duncan
Old May 7, 2004 | 10:49 AM
JesseT's Avatar
JesseT
Have you measured the voltage that reaches the solenoid of the starter when you try to crank. I got only 8V or something when I had this problem.
Old May 7, 2004 | 11:19 AM
220TC's Avatar
220TC
will try that mate, cheers
Old May 7, 2004 | 11:44 AM
chewyS2RST's Avatar
chewyS2RST
if its the original starter motor then thats more than likely the problem,
ive had the same problem with both my previous and present RS Turbos,
changed the starter and that sorted it.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
TPM961
Jan 15, 2018 10:50 AM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
