Efi rs turbo starting problems
Fleet Manager
As a few if you may know I converted my late spec efi xr3i to fiesta turbo ofac engine and management
Finally got all the correct parts together as I had an pattern part crank position sensor fitted before
But it still won't fucking start!!!!
It turns over very very strongly but just won't actually go
I here the pump relay go under the dash (very faint being an xr3i) the pump it's self doesn't make as notice as it's already to pressure
I have spark just won't bloody go!!!
What are the man things to check? What things commonly cause non starting on fiesta rs turbos? When it was a 3i it was always a case of nothing on the ignition rather than not firing?
Please help me
Please help me
Does the fuel pump prime on ignition two? It should prime for 3-5 seconds before stopping without the engine running
If it doesn't then the wiring from ecu too switch earth the fuel pump isn't right
P.s I put a set of stock injectors in mine and they wouldn't work, I tried another set and it fired straight up
Fleet Manager
It's got the whole inlet from the original xr3i, I've replaced the fuel pump assembly and tank previously it didn't prime this time as it was up to pressure, it's a standard xr3i tank and pump may undo the pressure reg to make sure till prime to pressure
Also I'm gonna chuck another 30 quid worth of super unleaded
I do have VXR injectors but will they work with the ofac ecu?
shit happens
I have a set of standard injectors if you want to borrow those to try mate, I think my inlet has other sensors on if you want to try those too, may have the map sensor somewhere too, glad to see your cracking on with it mate.
I made a start on the rs the weekend, going to finish the welding next weekend too, well try to finish lol
marky_g
15-08-2015 10:43 AM
