Limit of a standard Cvh?
The turbo will hit its limit before the engine mate
Get a stage 2 or stage 3 turbo and the Siemens injectors with your ofam and you will have a nice 200/220bhp
You will need a up rated clutch too
240bhp I would say is the limit, and to be honest if I was going for the hybrid turbo I would get a Newman phase 4 cam, double valve springs and solid lifters
Although I think a totally stock engine with ofam, injectors and stock rst t3 with -31 actuator and fmic will get around 200bhp and drive brilliant
Fleet Manager
Guess well just see how it goes gotta get the bastard running first what upper boost house do you use for the efi conversion I had a rely long escort rs top hose that worked but I changed it for a new pre cut hose and it's miles off , will I need a fiesta one?
Fleet Manager
Standard t3 I'm not going to go to far with the cvh as I'd rather go zetec if I'm going to buy rods and pistons I'd rather it be for a larger engine
I think rouse do a hybrid hose
For conversions, I got off the shelf hoses for my zetec conversion?
Get it all running on the cvh you have and have a lovely punchy 200bhp
Then when you are bored, 2.0 zetec with 1.8 sump set up, inlet and exhaust adaptor plates and new coolant hoses
Drill out your flywheel bolts and fit a uprated clutch
Then remap = job done with your turbo rebuilt too stage 3
Fleet Manager
Yep it was that one I think I'll make something up nearer the time and just make what I have work now
I can get my hands on some vxr injectors 75 posted so ill prob grab them I'd be happy with 200 and as I have basically a standard engine i think the 630s might be abit wasted as I don't intend to do any more to the engine for a while
I would say 190- 200 max this would allow you to drive it hard and be reliable as long as your engine is pretty sound to start with.make sure it has a decent clutch my s2 was 185bhp @ 15 psi never missed a beat ,ripped out engine built a 240bhp zvh and had nothing but grief engine itself was ok but every thing else around it seemed to fall apart . and the torque steer was awful
I have too agree
But people should remember that putting a 100+ extra bhp on a car is going too need some work
The jump from 185 too 240 is massive, you then need
Better coolers
Hoses
Mounts
Efi conversion
Brakes
Suspension
Clutch
And gearbox
So sometimes if your happy at 180/190bhp just leave it lol
Better coolers
Hoses
Mounts
Efi conversion
Brakes
Suspension
Clutch
And gearbox
TPM961
15-01-2018 10:50 AM
SMILER258
28-09-2015 09:04 AM
