group A ignition coil
cossie fan (unluckerly)
All it dose is supply battery voltage to the coil via a really triggered from the original coil wiring. As the loom may have resistance in it so you don't get a strong voltage to it!
You can just fit the coil in place of the original one using the normal coil wiring
Or you can fit it using a group a loom which is as I said a relay fed battery voltage supply. That uses the original coil wiring to trigger the relay in the new loom
well ok today i fixed may brand new coil groupe A magnetti
i took from the standard escort rs turbo loom the BLACK wire + to the + on the coil
and the two - green negativ also on the 2 -negativ pool on the coil
than i have my coil loom with a relay on it to supply power to the coil i made the positive wire to the battery the negative wire on the car earth and the positive wire next to the other positive black wire on the coil
but i still have one blue wire from the coil group a loom where i don t know where it comes????
thank you
thank you
07-10-2015 12:56 PM
