FAO karlos g..... Black top inlet
You have to unbolt from the engine mount. Pull the engine forward to get enough space to bolt it on then push it back. I've got that manifold fitted to my mk3
It's butted up tight against the brake balance bar so no good
I'm bolting my rs1800 style one back on as its modded already for top feed injectors, just needs a lick of paint
One good thing is I just cut all the brackets off for bonnet catch supports as the turbo didn't fit between rad and manifold and now I've moved my rad so far forward I have 3/4"s between the 4x4 cossie turbo and my big alloy rad, so chuffed, just got to make some brackets up
And weld my 3" down pipe into the system
Making loads of progress now
TrevCos
Modellers Corner.
24-08-2015 09:31 PM
