zvh conversion
its not c20let pistons in the zvh
its 86p c20xe pistons, c20let pistons are for zetec turbo route which i would do everytime over a zvh as its a cheaper option unless your staying mfi, and then its pointless because the mfi system will limit you to a max of 220bhp which a cvh can manage with ease
Can I just ask so I don't start a repetitive thread...
I was going zetec turbo but was going to buy a complete set up...
.. Calibra turbo pistons, bored out to 2.1, arp rod bolts, area six valve springs, focus Rs valves ang cams,rover turbo inlet cut and fiesta turbo throttle body, 440c injectors, adaptor plates, t34 hybrid turbo, KMS Management,
Does this sound like a wise buy? What would it be worth
dont run too much boost as the standard rods are limited to around 260/270bhp same sort of spec as mine and seems fine
otherwise if you can see it running then get it
Ben
Get some decent rods or go for an ST170 bottom end with a thick headgasket, I think it's from a FRS, I've read on here it's good for 350bhp. It'll be the route I'll go for but only stage 3 T3 for response.
Also I doubt you'll get the valve springs, A6 aren't in business at the moment as far as I'm aware.
And as for the OP, go full ZT, you're using the worst parts from each engine on a ZVH.
As said above, rods will be your weak point.
silver top 2.0
devil develoments valve springs
frs gaskets
c20let pocket pistons
stage 3 t3 with external gate and screamer pipe
blacktop inlet with frst pressure reg (just need to sort injectors)
grs cooler
airtec stage2 rad
gotech pro ecu and braided loom
and im speaking to a guy who has done a few friends steels rods for a good deal on steel rods with arps and glyco bearings all in with the pins machinced for my pistons ready to go £300ish
then looking to run 1.8ish bar boost, i did have a t34.48 but wanted more response
all in a fiesta turbo
Balls Deep!
Ditch the ZVH idea and do this if you happy with up to 350bhp...
https://passionford.com/forum/ford-e...onversion.html
ZVH is a terrible engine unless you spend massive money and that would be a waste.
I got sick of waiting and that was over 6 months ago, I used a cometic 1.5mm head gasket, with a brand new head so should be somewhere near the same as a 1.8mm gasket and used and skimmed head.
Engine Machinist
if t3, weather it be zvh or zetec it needs to be a .48 rear housing or you wont make more than 10psi
from what you will save not buying zvh conversion parts you will be able to buy the zetec turbo bits.
black top zetec inlet £35
efi pressure reg (you already have with the ofam/ofab?)
drill and tap the head for your exhaust manifold (free) and use all your exhaust including manifold and turbo
to fit bottom end is the same as a zetec
on ebay there is a kit to bolt your thermostat to the zetec head for £25
so in theory its cheaper to build a zetec than a zvh if your planning on ofam too
quick tips,
with silvertop's things like valve springs are £100 cheaper because use dont need new retainers (devil developments) so i would use the silver top with the c20let pistons, and frs gaskets and spark plugs are perfect
rouse motorsport do a bottom hose off the shelf to fit your cooling system and the zetec water pump, dont get the kit as you would need to use the zetec thermostat housing and its better to use the cvh one with the £25 adaptor plate
if you have ofab/ofac already get the car to at least start before changing the ecu to ofam before spending money
yep, they were running ofab with zetec chip, and everything on ebay these days is shit.
dubbs44 redrilled and tapped his head in 1 hour to match mine and was free and works great, why spend on adaptor plates and push turbos closer to the rad?
as i said the only adaptor plate i will use is the one on ebay for the thermostat because it works great
1/4 mile beasty!!!!
I wouldn't bother drilling the head out for a manifold when I did my first zetec conversion I bought a zetec flange on eBay cut my flange off my standard manifold and had it welded never once cracked or blew
As for zetec rods I've never heard of anybody bending one ? I might be wrong but at 300hp I think standard rods will be fine my old setup used to peak 26psi on standard rods
its all good
Thanks for all the information guys so can I use the standard rods with c20 let pistons..
And use a blacktop block with a silvertop 2 litre head
And a t34 turbo
And a t34 turbo
It's a lot of work to mix the black top block and silver top head, if you have a black top bottom end already then just source a black top head
Yes the zetec rods can be used with the c20let pistons but needs some machining to except the pins
Same spec as I have
Same spec as I have
its all good
nice 1 thanks mark
No worries, the drivability with the zetec is so much better than a cvh
Mine at 10psi and a stage 1 t3 on ofab wipes the floor with a cvh with steel internals and Newman cam, ported head and stage3 t3 at 16psi
Mine totally left it for dead as it did to a Audi s3
1/4 mile beasty!!!!
Unless you have a set of c20let pistons or are getting some second hand I wouldn't bother using the there are that many other sets around at cheap prices there's no need to mess around with vauxhall pistons anymore and if your going 16v turbo it's better to use c20xe pistons otherwise to run c20lets you have to deck the block
Mark I did run arp bolts with my old 16v spec
1/4 mile beasty!!!!
Of the top of my head I can remember how much my block was decked my pistons were very very close to Beeing level with the deck of the block but my head was a virgin Un skimmed head
its all good
[QUOTE=QplateRST!;6276229]Of the top of my head I can remember how much my block was decked my pistons were very very close to Beeing level with the deck of the block but my head was a virgin Un skimmed head[/QUOTE
Stuff it before I put my head back on I'm going to get it cc'd and checked to see what compression I have, my mate Wayne at wpe will sort me out with it
But while its out its stupid if I don't put steel rods in
As for someone who has a zvh I wouldn't say it is any harder or cost more to build a zvh and as for using the two worse parts for the engines sounds abit funny to me also because a zetec bottom end can do more power and torque than a cvh can with steel rods or with out and the head isn't as bad as people say also because the plugs don't blow out when running a lot of boost and you don't have to mess on with adapter plates or rover manifolds everything will bolt on.
If you want to build a zvh and have Vauxhall pistons get them put in like you would with a full zetec then drill 6 holes in the side of the block for water pump and tensioner buy a head gaskit and then bolt it all in.
Zetecs are good but zvh isn't bad also.
the zvh would be a good route if staying mfi as it as you say only requires the water pump mods and new tensioner and sitech headgasket.
Yeah but why mess on with adapter plates and manifolds and buy valve springs when all he wants is about 270bhp. To me if he wanted more than that he would buy steel rods and pistons. Just my input tho.
mk3ste
17-10-2021 10:09 AM
Johnny Knoxville
30-09-2015 07:21 AM
SMILER258
28-09-2015 09:04 AM
