Starting problem
Old May 6, 2013 | 10:57 AM
Johnstownred's Avatar
Johnstownred
Default Starting problem
Newbie to this site looking for some help
I have a 1990 H plate Erst
Been standing for a while but occasionally
starting it up
Recently it stopped starting , can't hear the fuel pump coming in on the the ignition
I have changed the pink fuel relay still nothing
Any ideas before changing pump
Thanks
Old May 6, 2013 | 11:08 AM
haz87's Avatar
haz87
Battery charged up?
Old May 6, 2013 | 11:11 AM
Johnstownred
Battery fully charged , turns over , don't hear fuel pump just click on the ignition when u go to turn it over
Old May 6, 2013 | 01:35 PM
rsmark86's Avatar
rsmark86
power probe to the fuel pump and test the voltage at the pump, if you can use a switchable probe you can use it to see if it powers the pump
also check for spark as you wont get an injector pulse without a spark.
its the thing with rs turbos it can be anything
and is the relay you fitted a new item or second hand, theres a lot of dead ones for sale these days, a way of seeing if the relay is the cause is to bridge the relay and if the car starts then it needs a new one
Old May 6, 2013 | 02:11 PM
RSmark84's Avatar
RSmark84
Could be the fuel pump seized itself. I parked mine up in my garage for the winter, the pump seized.
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
muffster
13
Sep 3, 2015 09:40 PM
nick8saff
Aug 16, 2015 05:35 PM
Sjieter
Aug 5, 2015 09:47 PM
