turbo HELP!!
Old 10-03-2013 | 03:48 PM
Nickesrt's Avatar
Nickesrt
Default turbo HELP!!
hi. im new at this i have a 90 spec erst and i have a escort cosworth t25 turbo can i use this if so would i get more power.. thanks for reading. nick
Old 11-03-2013 | 07:13 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Hi Nick, if it fits an RST manifold (think the T25 flange is smaller) then yes you can use it and yes you will make more power!
You will need a custom down pipe (Cossie one butchered to fit RST exhuast back section), a chipped ECU, a bigger intercooler, an uprated clutch and then a tune up.
Old 11-03-2013 | 07:14 PM
DixieTheKid's Avatar
DixieTheKid
Pick-up P100 Power!
I have a cossie T3, no smoke and play free for sale
Old 12-03-2013 | 01:54 PM
wilky's Avatar
wilky
small cossy t25 will fit has a t3 flange ,it's a nice size unit on a 1600cc ,you need a cossy down pipe ,i think the compwheel is 43mm around that on the inducer ,i up grade hem to a 46mm pulsar wheel which is the same size as 4x4 cossy wheel ,you need a 360 bearing if you going over 14 psi
Old 12-03-2013 | 01:59 PM
martysmartie's Avatar
martysmartie
Out of interest, how does the T25 make more power than the standard T3 turbo, which is larger?
Martin
Old 12-03-2013 | 02:57 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Martin
IIRC The Cossie T25 has both a larger turbine and compressor vs the RST T3, I think it's some where between a Stage 2 and 3 T3, Wilky mentions above about fitting a larger compressor wheel this would make it more like a Stage 3 T3... I think! lol
Old 12-03-2013 | 03:01 PM
wilky's Avatar
wilky
standard comp wheel is 40.5mm inducer and 60mm exducer [t3]
cossy t25 is 42.5mm inducer and 60mm exducer
also its has a smaller hub and tip lenght on the front will be longer
and grab more air [t25] spool quickeras well as turbine is lighter ect
2wd compwheel is 44.5mm inducer i'll have to check the lenght of the front blades
and compare to the cossy t25
Old 22-03-2013 | 04:49 PM
Nickesrt's Avatar
Nickesrt
Thanks for all reply. They have helped
JK12
33
26-04-2021 12:09 PM
RSBryden
06-09-2015 08:39 PM
cozzzzy power
04-09-2015 08:14 AM
turbowag
03-09-2015 08:07 AM
Jerry Ryan
02-09-2015 08:02 PM
Quick Reply: turbo HELP!!
