Turbo exhaust housing
11-03-2013, 07:34 PM
Hello all...
Really need some help... Trying to swap over my standard exhaust housing to a Cossie .48... As I'm using a crazycage tubular manifold..
Has anyone got any pics on how the actuator is ment to go and fit..!?
Help
Tiller
11-03-2013, 08:11 PM
11-03-2013, 08:17 PM
Did you use the escort actuator and bracket..!?
11-03-2013, 09:05 PM
This is as it stands now
Can anyone help..!?
11-03-2013, 09:59 PM
The annoying ginger guy
You may have to make or modify that bracket so that the wastegate can open and close properly, have ya tried un bolting it and putting the actuator onto the wastegate and see where it sits with enough movement
11-03-2013, 10:00 PM
Cos as far as I remember the actuator I got at work has a slight kink in the bar
11-03-2013, 10:08 PM
Could you get some pics at all..!?
Tiller
11-03-2013, 10:14 PM
I'll sort some out wont be till the morning, by looking though you have to move the bracket as most actuators are about that length
11-03-2013, 10:29 PM
11-03-2013, 10:46 PM
Balls Deep!
May need to use a Cossie actuator and bracket.
Is the compressor a standard RST T3, have you just changed the turbine housing?
11-03-2013, 10:51 PM
It's Standard RST Compressor housing and actuator, I have just changed the turbine housing correct.
12-03-2013, 10:30 AM
Wye Valley Hardcore
There might be a few pics on my resto thread.
12-03-2013, 11:05 AM
Balls Deep!
Quote:
Originally Posted by
TIL13R
Yeah might need a different acutator...
Stu @ M Developments
Ok,
Actuators, the definitive guide..
Here are three -31 actuators all for Cosworth's.
The one on the left is a 2wd Cossie T3 actuator.
The one in the middle is a 4wd sierra Cosworth T3 actuator.
The one on the right is a 4wd Escort Cossie T34 & T28 actuator.
The lengths are slightly different on all of them and as a result they all have these different rod ends too...
Hope this helps
I guess your planning on a bigger turbo later on? Or this will be the worlds laggiest 185bhp RST with a .48 turbine and stock compressor!
lol
12-03-2013, 05:13 PM
It's a turbo technics stg3 t3 but due to tubular manifold I need to run a Cossie rear housing...
12-03-2013, 07:09 PM
TIL13R
im looking a doing a manifold that keeps the turbo in its origonal position soon
12-03-2013, 07:19 PM
Bugga...! Done any help me now lol...
12-03-2013, 08:15 PM
Balls Deep!
TIL13R
Oh I see thats fine then mate.
12-03-2013, 10:04 PM
Karlos G
Just need to know what i need lol..
22-03-2013, 09:03 PM
Matt Baxter
16-09-2015 08:30 PM
Danielbetty
23-08-2015 12:52 PM
rsstav
Ford Focus RS Parts for Sale.
20-08-2015 07:45 AM
rsstav
Ford Focus ST Parts for Sale
11-08-2015 04:19 AM
