I've had to do some work on my car because the thrust bearing was faulty, so thought I'd do a few bits while I was at it, I wanted to see what turbo I've got its supposed to be a stage 3 T3 unfortunately when I took the boost hose off there was oil in it, checked the shaft and its got excessive movement so took the turbo off. I've looked for the .48 marking on the exhaust housing but theres no markings on it is there a way I can tell if it is?
also does anyone know the best place I could get it rebuilt or is it worth hunting for a t35?
Then I would say it's a stage 2 T3 (.36/50), stock turbo will flow for about 185bhp, stage 2 about 230bhp and stage 3 (.48/55) 300bhp.
My stage 2 made 231bhp at 19psi (Pushed to it's absolute limits) so your around that mate, a stage 3 at 21psi would see over 250bhp unless it's poorly setup.
comp wheel inducer are 46.5mm 4x4 cosy
44.6mm 2wd cosy i think lol
This might help me confirm if mine is a stage 2 or other than standard, I can get a turbo or .48 exh housing sorted out from you then, will give you a shout on faceache
If this is standar I think I'm gunna go for a 4x4 cosworth T3 and cosworth management need to split my engine make sure it is what it was suppose to be when I brought it as not a lot else has been wish I'd done more research before I purchased the car I scrapped lol
