steel bottem end
steel bottem end
brought a set of these today ....http://www.burtonpower.com/accralite...cv142-1mm.html
just wondered if these will fit them ebay item number
270998649766
270998649766
what sort of bhp willi get from this with ofab ecu and full race spec head
also what cc will the pistons make the block as the 1mm over bore
Ofab will make cock all, you can't get custom chips easily and injector choice is rubbish. You'll struggle to get past 220. And at that level the head is wasted.
What being really horrible, this is what we call 'catalogue tuning' at work, and the only thing it does is empty your pockets and fill part suppliers wallets instead
as for the efi i have a complete xr3i engine im starting to build thats what i brought the pistons today for
Have it chipped and set up on mfi, properly by someone you knows there stuff, ht racing at brands, or one of the guys over the dart ford in Essex like grove or oddkidd. A well set up 200hp rs turbo will be very quick indeed, you'll enjoy yourself and it'll cost you less than those pistons
For less than a grand: tuned mfi which is not as shit as you think.
Over a grand: chipped efi, worse than mfi in my opinion
Over 2 grand: cossie management or full aftermarket.
Seriously though, I have a lovely power engineering chipped ecu out of my old car. Ill post it to you for 75 quid, then you can take your car to have it installed and set up and you'll be happy as a pig in muck
its running 165bhp
but i have a new engnie to build efi
brought the steel pistons yesterday
getting the rods in a few weeks then
looking to get a steel crank and then im after a full race head where would be the best place
to get a full race head and what sort of price
camkit i can get cheap as a friend of mine works at kent cams
then i think ill be saving to get a different management
my budeget is around £2500 for the rest of the engine then what ever the manage ment is
i have thought about zvh /zetec ect but i want to see what i can get from the cvh as for suspension i have g max all round and brakes im uprating to mondeo ones and its all been polybush too
clucth will be 3 paddle
gearbox i not got that far yet
Well there are a few people on here that have around the 200+bhp cvh's so I would seek their advise.
Its always better to talk to someone who has done it first as they have been through all the trial and error of certain parts etc.
I have to ask though, why do you want a 300bhp cvh rs turbo?
its running 165bhp
crank £1100
flywheel £200
all steel
head £750
cam kit £200 for me !)
clucth £130 paddle thats with my discount
then its bolts gaskets
and s/s manifold £300 =£2980
well if thats what it costs then
its not like im trowing all the money at it in one hit so i dont mind if it dont come back out this due to engine rebuild then ohwell
but it will be an animal of a cvh right?
i guess i could save a few pennys and just have the standered crank polished
what else could be done to the standered crank whats the idear of grinding
the head flow and the ancilliaries are where your power is achieved.
ie injectors ,ecu and mapping
turbo, headflow , intercooler,
the stuff your on about buying will not gain you the power,
200hp is achievable on standard rods and pistons so why not but the ancilliries first then upgrade internals at a later date,
i hope somebody is building this monster for you
are you winding people up here or what?
and just ordered a stage 3 turbo
i have a large intercooler my problem will be ecu with ive just been offered a brand new omex 600 from a friend £150 as there skint
im using efi inlet so ill need to look into injectors
and yes ill be building the engine with some help from my friend
if you read properly im having a full race head being built
a chipped ecu on mfi with
a decent stage 3 turbo,
exhaust
front mount cooler
a decent spec cam and a little porting should see you around 190-220 which is more than enough and all for under a grand if you spend wisely
followed by a decent setup will surprise you
if keeping mfi best fit some new injectors or get them tested as mfi injectors arent interchangeable
