is it possible n how can i move the starter motor from back to front??
05-09-2012, 06:42 PM
my mates got an ib5 at his, well i think it is.
got all the right mounts n bits i need but the starter motors on back?? anyway i can change it to front some how or have my starter on back???
cheers
05-09-2012, 08:14 PM
think the escort si had a starter at the rear, no reason why you can't make it work.
05-09-2012, 08:45 PM
Quote:
Originally Posted by
luke19790_3
will the starter fit though?? if so im onit
05-09-2012, 08:49 PM
is your engine a cvh, if it is the oil filter will be slap in the way
05-09-2012, 09:26 PM
studabear
it is yes, but i wanted it also for when i do my 2.1zvh?
06-09-2012, 11:35 AM
Zetecs were available as rear starters, so should work.
06-09-2012, 03:58 PM
will the cvh bell housing bolt onto the ib5 to swap starter back to front??
06-09-2012, 04:00 PM
Not sure about that but the PTE (late 1.4 MPI Escort) had a front starter IB5
06-09-2012, 07:20 PM
from looking at the two boxs they are very much the same.
ill get some pics up
06-09-2012, 08:19 PM
try convert to rear starter if poss, it was done to stop the starters heating up from the downpipe
06-09-2012, 08:28 PM
16vzetec
not possible, there is an oil pipe in the way :-( front mount itll have to be?
06-09-2012, 08:47 PM
ib5? out of mk6 escort 1.6 si
cvh rst lsd
they look exactly the same and all bolt holes line up?
06-09-2012, 08:48 PM
the oil feed pipe is in way of rear starter motor placement!!
Ben26
Ford Focus Diesel
18-08-2015 03:42 PM
ekjim
17-08-2015 08:57 PM
Shows & Track Days
15-08-2015 06:25 AM
track.focus'd
12-08-2015 05:53 PM
