Escort mk 4 cab door
Glovebox out, unscrew and remove heater vent piping from behind the dash for the LHS door. that will give access to the top nuts and spacer. for the bottom 2 nuts and spacer remove speaker grill and speaker while its still mounted on the bracket. You'll find them right behind there.
For the RHS door same as other side for the bottom, for the top reach up and its near the relay bracket for the fuel pump relay etc.
OR........... pull the door pin up and out of the door bracket. Should be a metal C clip at the bottom of the hinge/bracket simply wack with a hammer upwards to push the pin out.
