cosworth management??
Hey folks just a quick question do the wires on the tps have to be switched around to run a pf09 on l6 management? Cheers alan
Yea i has pectak board but also i dunno what chip or if its ment to run the spec of the engine it doesnt start and run without green 803s tho lol
You have to open the ECU and visually inspect the chip, if your lucky someone will have wrote information on it, MSD even keep a S/N database as well which is handy, only applicable with there EPROM'S of course.
When you say it has a Pectel board what do you quantify by that, a Pectel board is merely a board to decrypt certain chips so they can be read.
There is another type which adds features, such as 12 position boost etc, but I am pretty sure that you can't use it on the early (2WD) versions of the ECU, like you have.
Martin
Martin
I really dont have a clue about pectal board but it has 4 boards 2 big ones and and a 1-cpv2 and a 2-cpv2 i dunno what that is mibby yous will haha
From memory the PF01 is open circuit at idle where as the PF09 is not and actually produces a resisted circuit. Without the ECU being calibrated for a PF09 then the ECU will assume you're on throttle all the time.
To run a PF09 on a L6 harness the outer 2 wires need swapping around but that means the L6 ECU won't understand what is going on as the pins on the ECU were configured for a PF01. I don't know if this can be accounted for in the ECU calibration or not to be honest.
Martin
JK12
33
26-04-2021 12:09 PM
03-11-2015 04:08 PM
