Cold start problem, lumpy
Old Feb 26, 2012 | 12:55 PM
Fowley's Avatar
Fowley
Cool Cold start problem, lumpy
1987 escort rs turbo mk 2
When starting it was very hard to start and when it finally started pressing the accelerator at all would stall it untill it got hot, found out it could be the cold start circuit which is the heated seat fuse if I'm correct, we put a fuse in the heated seat fuse and when we started it, it started fine and could rev it and was fine, apart from it is lumpy as anything like its only just running on 2cylinders we have found a few plugs disconnected anyone know much about the cold start system or what to check for??
Old Feb 26, 2012 | 01:34 PM
Sjieter's Avatar
Sjieter
i keep mine disconnected , starts first time.
when -8°c it needs a little longer but idles smooth.
previous owner also didn't bother to repair it.
Old Feb 27, 2012 | 10:18 AM
bigrs's Avatar
bigrs
I have always had my cold start disconnected was told to do this by my mapper, apparently its not need for our british weather. Starts first time cold and hot.
I think your problem is something else.
Old Feb 27, 2012 | 07:29 PM
Fowley's Avatar
Fowley
mmm, I rec-connected it and it started straight away. Lumpiness seems to have gone away with fuse in, so looks like that was problem!
Old Feb 27, 2012 | 10:09 PM
blackbeautyzetec's Avatar
blackbeautyzetec
Im sure the I saw posted, something about that heated fuse switch being something to do with the fueling ecu. May be wrong but It would make sense
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
The Enigma
13
Aug 20, 2015 09:38 PM
Archiejay
Aug 12, 2015 12:07 PM
