overheating
Old Nov 19, 2011 | 03:08 PM
Sjieter's Avatar
Sjieter
Default overheating
hi, fixed my running and turbo problem.
turns out my igntition timing was all wrong and my strobelight is broken...
Timing actually fixed my running and turbo problem, finally have some boost
Now i still have one problem the car is overheating well at least i think it is.
Put in a MSD fan switch , 82°C thermostat and temprature sender but still the car is running between norm and red.
The fan comes in between norm and red too.
Just hope i didnt damage the radiator when refitting my turbo from the rebuild, i hit something but cant really see any damage..
Or is the temp gauge fooling me?
All answers are welcome , thanks
Edit : between norm and red i mean between the n of norrm and red, it sometimes goes to the O.
Old Nov 19, 2011 | 05:08 PM
studabear's Avatar
studabear
Does the fan come on and go off by itself?
Old Nov 19, 2011 | 05:47 PM
Sjieter's Avatar
Sjieter
yes it comes on and goes off by itself but it comes on very late.
does it matter how you connect the fan switch like + and - ? cause you have to cut off the original connector and put on another.
But actually i dont know if it really is overheating, i bought a temp sender from MSD and i dont know if its playing up or damaged.
It's like the car is heating up pretty quickly, after like 2-2.5 kilometers the temperature is almost at the M from normal and it really goes up quickly.
When the temp reaches between n from norm and the red it suddenly goes down again.. to about o from norm..
I really need a quick solution cause i need the car for work..
My parents are bringing me to my work which is really embarressing
Old Nov 19, 2011 | 06:39 PM
studabear's Avatar
studabear
Looking at the msd site it says the switch can be wired either way,
If the fan is coming on and off I wouldn't be so worried,
Is your thermostat in good condition, also how is the gauge when driving?
Old Nov 19, 2011 | 07:02 PM
Sjieter's Avatar
Sjieter
haven't really checked the thermostat when it opens, but it's only 2 months old and didn't look damaged or anything.
Maybe i'll just get the housing off and check everything.
All the things i wrote in my previous posts is while driving.
it's always so high up the gauge.
i never let the car idle that long to get it up to that temprature.
I'll get a new temp sender from ford self , as i trew away my old ford one..
The rs turbo has a self bleeding cooling system right or do i still have to do something to it?
Thanks
Old Nov 19, 2011 | 07:10 PM
tejy's Avatar
tejy
have you checked if your engine is actually getting too hot? once the temp gauge reads red pull over and see if your engine is hotter than normal, the gauge might be dodgey because of the thermostat. as mentiioned above whats the condition of your thermostat? might be worth having a look at it. its only 3 bolts to undo it. i had a similar problem like this, changed the thermostat with a msd one and got a new rubber seal as the old one was f*cked. once it was changed i never had another problem with it the gauge telling me that the car was overheating
Old Nov 19, 2011 | 07:13 PM
Sjieter's Avatar
Sjieter
i'll just buy a new thermostat , rubber seal and a new gasket and go from there .
Thanks for your help guys
Old Nov 19, 2011 | 07:19 PM
Robs Frst's Avatar
Robs Frst
Have you flushed the system and checked for air locks does happen.
Old Nov 19, 2011 | 08:23 PM
saman's Avatar
saman
have u tryed flushing the system an is ur rs turbo running rich cuz that can cause it overheating take it to a proper tuner eg jano oddkiddcreations or call him on 07984071567 he will guide u with what is happening hes a very helpfull guy.
cud be the following eg:
air lock in system
thermo
faulty guage
radiator
to flush the system easy way is to take the pipe off the top of the thermo wen running an let the water come out then put the pipe back on that shud do it if thats any help hpoe u find out what it is. when u find out what it is let me know what it was just post on hera so every one knows what it was thank you.
Old Nov 19, 2011 | 08:57 PM
studabear's Avatar
studabear
He's in belgium
Old Nov 19, 2011 | 10:21 PM
Sjieter's Avatar
Sjieter
jup in belgium
I'm going to make an appointment for a setup in Holland, but first i want to take on this little problem. i'm just not driving it anymore like this.
Can they fully setup a car that is still running in from a rebuild ?
Or is it ok to use full boost (0.55 bar ) for a short period of time just for the setup?
ive got like 28 kilometers with the rebuild engine..
Thanks for the help
Old Nov 21, 2011 | 06:01 PM
Sjieter's Avatar
Sjieter
what color code of temperature sender does the rs turbo from 1986 have?
I'm really starting to think its just the temp sender fooling me because the fan always jumps on really high up the gauge and it's not that hot really...
According to a friend there are 3 colors..
My 1st cilinderhead had the right one but they trew it in a metal container that is now full of other stuff so i just cant find it anymore
Old Nov 23, 2011 | 11:38 PM
Sjieter's Avatar
Sjieter
can someone please tell me what color the Rs turbo s2 temperature sender has?
Got a purple one from MSD , pink one from Ford..
Old Nov 25, 2011 | 04:13 PM
Si74's Avatar
Si74
My original Ford one was pink but I think the one I got from MSD
was green? will check it tomorrow.
Old Nov 25, 2011 | 05:16 PM
Sjieter's Avatar
Sjieter
with the pink one in the water temp gauge goes to just under red. but when i check the temprature with a laser or a thingy with 2 wires on it shows 92 degrees..
Purple one is the same. Really want to know why it is showing so high up the gauge..
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
Ade
Feb 8, 2007 05:11 PM
kurdt5
Jul 17, 2006 03:01 PM
fiestaturbo1984
Feb 19, 2006 03:51 PM
woodz77
13
Nov 6, 2005 03:02 PM
