brake upgrades
Boost Junkie
other than the usual cossie stuff what can you use to upgrade stadard brakes? i heard of mk3 mondeo calipers and cossie discs, but what calipers? there are loads of diff mk3 mondeo models, plus isnt there a upgrade using the st170 300mm discs and some calipers from another ford????
Mk3 Mondeo Calipers & Pads, with st170 300mm Discs - Needs 12mm spacer washers/plate to move the calipers inwards, away from the hub and the hub bolt holes need opening out by 2mm to 12mm iirc and Voila!
I run this setup with EBC YellowStuff Pads and its pretty good, stops really well from cold and i've done 2 track days at brands hatch with no fade! Im going to change to drilled discs next, purely for looks!
See the forsale section...
