boost controller??
Old Sep 23, 2011 | 12:26 PM
lewis.philcox's Avatar
lewis.philcox
Default boost controller??
is it possible to have a variable dual stage boost controller so one preset can run 7psi and one can run 15psi safely for example or am i better just leaving it setup at 15 lets say
thanks
Old Sep 23, 2011 | 12:51 PM
chaffe's Avatar
chaffe
Turbocharging Technician
yep it is totaly posible
Old Sep 23, 2011 | 01:01 PM
lewis.philcox
Thank you, now is there a particular brand of boost controller i should use and anything to be aware of?
Thanks
Old Sep 23, 2011 | 01:04 PM
chaffe's Avatar
chaffe
you can do this with an AMAL valve, and various sized jets. Does your car currently have an AMAL valve?
Old Sep 23, 2011 | 01:05 PM
oldford's Avatar
oldford
A simple On-Off switch will do the trick. Connect the switch in either electrical connection to the amal valve.
Old Sep 23, 2011 | 01:06 PM
lewis.philcox
im going to assume i dont have an amal valve seeing as im pretty sure im running a -31 actuator, 15psi boost and chipped ecu
Old Sep 23, 2011 | 01:27 PM
chaffe's Avatar
chaffe
littlr ound thing cream and brown in colour, with the actuator pipes and compressor pipe going through it
Old Sep 23, 2011 | 07:28 PM
Canada1's Avatar
Canada1
Turbosmart makes a nice dual stage boost controller.
http://www.awdmotorsport.co.uk/shope...no?id=60&bc=no
Old Sep 23, 2011 | 08:00 PM
fraser9764's Avatar
fraser9764
So thats 2 bleed valves then...
Ive got the a turbosmart electronic controller, eboost street 1, its utter toss and will soon be replaced by an apexi avc-r or greddy profec b spec 2
Old Sep 26, 2011 | 01:17 PM
Canada1's Avatar
Canada1
I prefer the manual type with a solenoid switching between settings. Less fuss than with pulse width modulated boost controllers. (Nothing wrong with the 2 stage manual boost controller I linked) Keep things simple - less problems.
Old Sep 27, 2011 | 10:27 AM
lewis.philcox
that is the sort of thing im looking for! il see what the bank manager says when the conversion is done then... anyone recommend turbo timers or do i just stay with the car for a bit of time to let it cool?
Old Sep 27, 2011 | 02:31 PM
Canada1's Avatar
Canada1
If you are sensible then a turbo timer is not required.
Old Jan 24, 2012 | 11:39 AM
Red16's Avatar
Red16
What problems did you experience while using the Turbosmart E-Boost?
Old Jan 24, 2012 | 11:44 AM
Stu @ M Developments's Avatar
PassionFords Creator
We fit these to lots of RS Turbos, they work extremely well.
http://shop.motorsport-developments....ller-297-p.asp
Old Jan 24, 2012 | 11:50 AM
fraser9764's Avatar
fraser9764
Unfortunatly it still fitted to my car, it does the job I suppose but I have never been able to smooth out the transition between target pressure and held duty cycle. Resulting in a surge like effect,
Its cheap for a reason, very lacking in loop tuning options, it isn't even a true close loop system as once the target boost is reached, the output just drops to a user defined duty cycle.
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
