S2 overboosting!!
Old Sep 14, 2011 | 07:11 PM
EoinXR3's Avatar
EoinXR3
Default S2 overboosting!!
I know it would have been delt with before but i bought a S2 project, it was non running, i have it running now( used another metering head ).
The amal valve pipes were all missing so ive got them connected back to
the wastegate, turbo and the airbox,
Took it a run and its way overboosting i didnt floor it but even half throttle it will boost to at least 25psi( thats as high as my gauge goes) then drops back to 15 or so.
what would be causing it?
Old Sep 14, 2011 | 07:17 PM
Sjieter's Avatar
Sjieter
maybe it has another boost control? and with you plugging in the amal valve it goes way higher? just a suggestion, could also be that the actuator is wound up alot and that it was running the desired boost level without any other boost control?
Old Sep 14, 2011 | 07:23 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Actuator too tight?
unplug amal valve and it should half the boost i'd imagine, must be chipped also!
Old Sep 14, 2011 | 07:24 PM
EoinXR3's Avatar
EoinXR3
how can i reduce it?
Old Sep 14, 2011 | 07:26 PM
Sjieter's Avatar
Sjieter
as vroom psh suggested unplug the amal valve, or losen the actuator arm a little? what is the boost pressure it should run on actually?
EoinXR3's Avatar
EoinXR3
Actuator too tight?
unplug as in the electrical connection?
Old Sep 14, 2011 | 07:27 PM
Sjieter's Avatar
Sjieter
jup just unplug the little plug on the side of the valve
Old Sep 14, 2011 | 07:29 PM
EoinXR3's Avatar
EoinXR3
i dont know what boost it should run, i got it as it is, it has a spare ecu with should i try it on? there is nothing on the one fitted to say its chipped
Old Sep 14, 2011 | 07:31 PM
Sjieter's Avatar
Sjieter
well because you dont know what boost pressure it should be running on i suggest you take it for a setup. i'm sure alot of people would say the same.
Did you ask the previous owner ? maybe he knows what boost it was running on before you bought it?
Old Sep 14, 2011 | 07:33 PM
jamie rst's Avatar
jamie rst
you might be best taking it to have a good tune/set-up at a good company or give one a call at least if there any good the will try and point you in the right direction.
do you know what the actuator was set to?
but if you unplug amal valve and it will give you half the boost.
what pipe did you us for the amal valve, because if the inside diameter is to small this will cause it to over boost.
and has it got the correct jets in the amal valve as this will all so cause it to over boost.
hope this helps in some way pal
Old Sep 14, 2011 | 07:44 PM
EoinXR3's Avatar
EoinXR3
i know i should get a set up done but theres no where near me that can do one( i dont think, i live on an island)
pipe i used is fuel hose and is plenty big,
and jet size dont know.
all a bit unhelpful to you all
its been though a few owners since it last ran so ive no idea who would know
Old Sep 14, 2011 | 08:36 PM
vroooom ptssssh
It Wasnt Me!
Easiest setup you could do is connect actuator onto the turbo compressor via a vacuum hose, loosen the 11mm nut on the actuator, unhook it from the turbo and note tension, did it spring off or was it just fairly slack? Adjust the actuator rod until it just needs pulled slightly and hooked back onto the wastegate...standard boost is 7psi, standard boos tlimit is 10psi, your ECU must be chipped as it exceeded 10psi and didn't hit the boost limiter as it rose to 25psi and dropped to 15.
if you want the standard amal valve setup, makesure all the hoses are in the right order, and do as I said above with the actuator, there is no real BENEFIT of running the amal valve but if it works then theres certainly no harm in using it.
What Island are you on?
Old Sep 14, 2011 | 08:47 PM
EoinXR3's Avatar
EoinXR3
thanks for that, i'll try that tomorrow
whats the alternative to the amal valve set up?
gotta say tho running that much boost gives some awesome chatter
however i know it'll blow the engine
Orkney is where im at
Old Sep 14, 2011 | 08:55 PM
vroooom ptssssh
It Wasnt Me!
Yea it won't last long like that! lol
alternative is as said, straight pipe from actuator - compressor housing nipple, OR Bleed valve, but you cannot lower boost with a bleed valve only raise...
DON'T buy an electronic boost controller, waste of money...
Get it down to AVA next time you're on mainland
Old Sep 14, 2011 | 08:56 PM
stevealien's Avatar
stevealien
10 Year Member
have you got a bleed valve mate?
thats the easiest way to set it up rather than keep adjusting the actuator.
simply fit one inline if you havent got one,between turbo and actuator(on your fuel hose you used.)
id set it at about 12 psi and see if it drives ok,take it easy as your fueling needs to be matched to your boost etc and if it feels like its holding back then back off the boost.
if it drives ok then tweak it a bit till your happy.
i run 18psi on mfi with no probs mate
but if your unsure what your doing,then run something like 8 or 10 psi till you can get somebody to set it up
Old Sep 14, 2011 | 09:03 PM
EoinXR3's Avatar
EoinXR3
yeah i got a bleed valve from MS Developments, i give things ago tomorrow and try and get the boost down too 10psi.
cheers all
i'll let you know how i get on
Old Sep 14, 2011 | 09:12 PM
vroooom ptssssh
It Wasnt Me!
He may still need to slacken the actuator....you can't lower the boost with a bleed valve, unless it's piped up wrong or the amal valve is missing it's jets then the actuators too tight!
Id run standard boost until you get it set up, as you don't know if the fuel will be correct on boost....
Old Sep 14, 2011 | 09:19 PM
stevealien's Avatar
stevealien
10 Year Member
you cant lower boost with a bleed valve???
of course you can
it allows you to fine tune your boost,with mine i can turn it down to almost sod all and up to over 25
agreed you need to set the correct preload on your actuator too,so you have to stretch the actuator rod about 3 or 4mm to get it on.
Old Sep 15, 2011 | 06:18 PM
EoinXR3's Avatar
EoinXR3
had a look today, amal is piped correctly so i just unplugged it
its now running 15 psi, bit high yet maybe?
but it seems ok, running smooth etc so think i'll try it at that untill i can get off the island and get it set up proper
thanks for all the help, couldnt have sorted it otherwise
Old Sep 15, 2011 | 07:04 PM
vroooom ptssssh
It Wasnt Me!
of course you can
No, you have miss-understood what I have explained.
if you have your actuator set to 20 psi, and you fit a bleed valve...you cannot lower the boost below 20psi...as it is a BLEED, so even fully closed you will have minumum 20psi.
HTH
Old Sep 16, 2011 | 03:59 PM
bigkev's Avatar
bigkev
Default just get rid of amal
feed the hose from the amal back io to the turbo itself. u then block the hose into the fuel meter . In took mines out wen i first got my rs , just as pain,
TIFF
Jan 1, 2006 10:15 AM
jonny gav
Ford Focus RS
Jun 8, 2005 11:27 AM
007
Nov 14, 2004 05:15 PM
TurboBlower
Oct 15, 2003 10:49 AM
