Back end lockup :(
Old Jul 26, 2011 | 05:37 AM
wedge07's Avatar
wedge07
Default Back end lockup :(
Hi this morning under harsh braking the back cossie brakes i put on my rst locked up, anybody know of any valves i can put on to make this not happen? Cheers
Old Jul 26, 2011 | 05:46 AM
I run the in line valves from a ka or fiesta,and i have removed my standard load valves ,my rear disks and calipers are from a focus so maybe slightly smaller aswell. Got the valves on my track car aswell and they work fine on that under heavy braking
Old Jul 26, 2011 | 06:46 AM
Antti O's Avatar
Antti O
Hi
do you have any pictures of those line valves? I have exact same problem with rear brakes. Front 4x4 cossie brakes and rear cossie 4x4 brakes with wilwood bias valve.
Old Jul 26, 2011 | 08:03 AM
tasos77's Avatar
tasos77
rs turbo from Greece...
Have you done any changes to the brake lines or just binned the standard compresators an putted the ka valves?
Old Jul 26, 2011 | 09:55 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
The best setup for this is using NON ABS brake lines and compensators off an escort.
You will need a 23 rating master cly and remove all the current lines. ALL OF THEM!
The non abs compensator valves can be changed in angle to allow less or more pressue to the rears.
No mods are required to fit and the parts are available pretty easy.
Old Jul 26, 2011 | 10:13 AM
Rogeyboy's Avatar
Rogeyboy
Jano - If you already have a non-ABS setup just adjust the compensators, by rotating them?
Old Jul 26, 2011 | 10:53 AM
Versus_Creations
Ask me a question!
Thats correct changing the angle will effect the bias.
Old Jul 26, 2011 | 03:22 PM
wedge07's Avatar
wedge07
I dont get what u mean or where these are? Soz for bein thick lol
Old Jul 26, 2011 | 03:59 PM
xrmalin's Avatar
xrmalin
I think jano is reffering to these on the left of the picture mounted on the bracket
These are on my 3i as i dont think turbo's have them
mark.
Old Jul 26, 2011 | 04:11 PM
Karlos G's Avatar
Karlos G
Balls Deep!
I have those on mine, so what angle do you adjust and what way for less rear force?
Old Jul 26, 2011 | 05:06 PM
On mine i removed my abs and made up some new pipe work .on my s2,focus rs front brakes and standard focus rear disk brakes
On my track car,this runs st170 front brakes and st150 rear brakes
Old Jul 26, 2011 | 09:51 PM
wedge07's Avatar
wedge07
I have them on mine, as mine was an xr3i, but never had abs? So which way do i spin em n how much? cheers
Old Jul 26, 2011 | 10:16 PM
Versus_Creations
Ask me a question!
If you tilt them so the front of them is facing higher towards the bonnet, you will get less bias to the rear. You will need to mod the bracket slightly to allow the angle change.
Old Jul 27, 2011 | 08:34 AM
Antti O's Avatar
Antti O
Do you have any idea why my rear brakes are 10x more powerful than fronts?
In mot station they told that rear brakes are very powerful compared to fronts. I have now wilwood bias valve limiting -59% rear brakes but still in rollers rear are more powerful. There is 4x4 cosworth calibers & 2wd discs in front and 4x4 cosworth 273mm rear discs & calibers.
My master cylinder is ABS rst standard.
Old Jul 27, 2011 | 09:26 AM
tasos77's Avatar
tasos77
have you used one fiesta-ka valve to each side on the rears? Makes any difference if i put them after the master cylinder? one to each pipe
Old Jul 27, 2011 | 09:46 AM
OldDan's Avatar
OldDan
You need some inline valves. We use some on MX5 race cars from a Mk1 Mondeo.
Old Jul 27, 2011 | 11:03 AM
Versus_Creations
Ask me a question!
Are you using non abs lines and non abs compensators with your ABS master cylinder.
Old Jul 27, 2011 | 12:55 PM
Antti O's Avatar
Antti O
I am using abs master cylinder. First outlet is splitted for front brakes and second output is going rear of the car and there splitted for rear brakes. Between that line is normal wilwood bias valve. There is no more original axle bias abs system valves in use.
Old Jul 27, 2011 | 01:05 PM
DazC's Avatar
DazC
Antti,
On your master cylinder, the forward most port should be operating your front brakes and the rear port should be operating your back brakes. Is this the case?
Old Jul 27, 2011 | 02:12 PM
Versus_Creations
Ask me a question!
Simple drawing for you..
First is using an inline bias valve.
Next is using NON ABS lines and Compensators.
Old Jul 27, 2011 | 03:12 PM
Karlos G's Avatar
Karlos G
Balls Deep!
So driving up hill has the same effect and driving down hill applies more braking force to the rear?
How much do you recommend tilting them by, 45deg, 22.5deg, etc.?
Old Jul 27, 2011 | 04:16 PM
Versus_Creations
Ask me a question!
It depends on the car weight brakes lines etc etc.. Each car will be very slightly different.
Old Jul 27, 2011 | 05:02 PM
Yes one on each side ,on my master cylinder i have only two take off,s one front one rear ,thats why they are here on my cars
Old Jul 28, 2011 | 09:28 AM
Antti O's Avatar
Antti O
Originally Posted by DazC
Antti,
Nope, forward port is operating rear brakes.
Is there different size brake pistons in master cylinder?
Old Jul 28, 2011 | 12:56 PM
tasos77's Avatar
tasos77
willwood brake bias valves has one inlet and two outlets??
Old Jul 28, 2011 | 03:18 PM
DazC's Avatar
DazC
The front chamber is meant to work the front brakes and the rear chamber works the rear brakes. There is a spring between the 2 chambers and plungers which makes the rears come on first for a brief moment to make the car stable under braking. I think the diameter of the master cylinder chambers is the same but they could be different in terms to length and shape.
If you swap the chambers I can only imagine the problems you could cause.
Old Jul 28, 2011 | 05:57 PM
Antti O's Avatar
Antti O
Okay.. if this is FACT i have to modify brake pipe connectors and swap those pipes. I report later when i have done this. There is different thread in each pipe connector i think so i cant swap those directly.
Old Jul 28, 2011 | 05:59 PM
mentalasanything's Avatar
mentalasanything
Ah Antti, this is probably the reason you are experiencing what you are!! The front port is also larger than the rear port.
Swap them round with some adapting pipes first and have a go.
Lee
Old Jul 29, 2011 | 06:32 AM
Antti O's Avatar
Antti O
I have picture here. This is how my brake setup was before modifying it. I am not sure if master cylinder outputs are connected precise as factory built it but you get idea. So based my information and this picture i cannot understand why there is some difference between front and rear output in master cylinder.
And this is my current setup, front brakes powerless and rear brakes too powerful.
Old Jul 29, 2011 | 09:04 AM
Versus_Creations
Ask me a question!
whats the matter with hand drawn pics ffs. Makes me look like i wasnt bothered. Next time keep it simple
The fronts need their own outlet from the master cly. Not joined like you have from 1 outlet.
Just follow my pics it will work fine.
Old Jul 29, 2011 | 09:09 AM
Antti O's Avatar
Antti O
My master cylinder have only 2 outputs..so maybe bit difficult to do that what you suggest.
So do i have to replace master cylinder..
Old Jul 29, 2011 | 09:49 AM
Versus_Creations
Ask me a question!
So basically your problem is down to the wrong parts fitted pal.
You will need to use a master clyinder from an escort mk3/4. Or adjust/mod the one you have to work right. It comes down to what you are using really. Get some pics up. Do you know what its off.
Old Jul 29, 2011 | 09:54 AM
Antti O's Avatar
Antti O
It is original S2 RST with ABS system. 23mm. Fluid reservoir is from non-abs orion.
Old Jul 29, 2011 | 11:15 AM
Antti ,have you also removed your standard rear load compensators ,on mine i run standard rst master cylinder ( 2 outlet) abs removed ,standard rear load valves removed and replaced with ka versions ,no lock up no matter how hard the braking on both my cars ,i dont run cossie rear brakes though ,st 150 on one and standard focus rear disks on the other
Old Jul 29, 2011 | 11:35 AM
Antti O's Avatar
Antti O
Yes i have removed those. Look picture.
What is interesting i am currently limiting -59% rear brakes and those are still much too powerful, front brakes wont grip unless i press pedal really hard then something happens.
Old Jul 29, 2011 | 12:51 PM
Versus_Creations
Ask me a question!
Do you have the T piece on the inner wings?
Old Jul 29, 2011 | 04:13 PM
Rob_DOHC's Avatar
Rob_DOHC
I think your problem is that one of your real wheels is thinner than the other and off to one side.
IMO
Both mastercylinder bores should be the same size as originally it was a diagonal split.
I would suggest that perhaps your master cylinder is defective OR you have air trapped, try a seriously good bleed. Using my new master cylinder i had to depress the brake pedal over night to release trapped air.
Im using RS turbo front callipers with with cosworth disks and standard rear drums, all compensator have been removed and replaced with new lines and a willwood bias valve.
My valve is adjusted to around the middle at the moment and all is well.
You can try swapping the MC connections over but im not convinced it will help you, if EVERY thing else fails you could always fit the inline compensator's and your willwood bias but i think you have an obvious problem somewhere.
Rob,
gabbo
Aug 28, 2015 03:56 PM
Ben26
Aug 27, 2015 08:56 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
