Possible engine damage?? Help..
Old Feb 7, 2011 | 09:39 AM
Joe91's Avatar
Joe91
Default Possible engine damage?? Help..
Hi, this morning on the way to work I was driving along and got stuck behind some idiot driving far to slow, i over took them in 3rd and I think I hit the limiter although I didn't see the rev counter at the time..
Anyway as soon as I thought I hit the limiter, the car just died so I bump started it in gear and it went again but there was a very loud knocking/tapping sound coming from the engine, I couldnt go over 30mph and didn't know what I had done wrong, I was told rst's don't like the limiter and I did do it by accident..I'm worrying that I'm going to have a big problem, would
Anyone know what I'm talking about sort of or have any idea what it could be?
The car starts and runs but sometimes it will cut out, I did drive it a mike or so to get to work so it's drivable..thanks
Old Feb 7, 2011 | 10:33 AM
craig rst kid's Avatar
craig rst kid
sounds like bottom end problems get a compression test done unless its cam and follower damage not good either way
Old Feb 7, 2011 | 11:04 AM
zippyobrien's Avatar
zippyobrien
Stuck lifter ?
Old Feb 7, 2011 | 11:49 AM
series_one_rst's Avatar
series_one_rst
the valve gear in cvh's are quite weak. a compression check should show up a problem. and point to a cylinder. takethe rocker over off and have a look for broken springs, rockers etc. the limiter on my s2 was well violent! backfired like a bitch! can't be good for any engine.
Old Feb 7, 2011 | 11:52 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
possible you pulled the rocker stud out the head, snapped a rocker, killed a lifter to name a few things. Dont turn it over any more or do any tests on the engine untill you remove rocker cover and check here first.
then update with what you find.
Old Feb 7, 2011 | 12:52 PM
luke19790_3's Avatar
luke19790_3
Take the cam cover off, have look at the arms
Old Feb 8, 2011 | 07:02 AM
Joe91's Avatar
Joe91
I've done a compression test and they were all reading fine, I'm going to take the cover off the head a bit later on and see if there is anything I can see, what should I be looking for? I'll have a mechanic to help me out aswell.
Also my bonnet is stuck down as my mate dropped it shut instead of pushing it shut so I have to get that open first!! Any easy way?
Thanks.
Old Feb 8, 2011 | 07:18 AM
chaffe's Avatar
chaffe
Turbocharging Technician
its not popped a boost hose off has it lol
Old Feb 8, 2011 | 07:46 AM
Joe91's Avatar
Joe91
Naa I've checked the hoses, i don't think that would make the engine run like it is though haha I wish it was something that simple!!
Old Feb 8, 2011 | 10:32 AM
Rob_DOHC's Avatar
Rob_DOHC
My bonnet cable broke one, if you jack the front of the car up you can JUST about wiggle a hand and screwdriver up there to push the latch,
Rob,
Old Feb 8, 2011 | 12:21 PM
Joe91's Avatar
Joe91
Yeah cheers rob I did the same as you said and it was fine..
The good news everyone is I snapped a rocker in half, just the 1..I'm going to replace them all and all the lifters as it was a bit tappy. Thanks for the help..
Old Feb 8, 2011 | 12:46 PM
Jimmyc's Avatar
Jimmyc
Glad you sorted it mate.
I wouldn't change just the lifters though, you need to change the cam and lifters at the same time,or youll just kill the lifters again.
Old Feb 8, 2011 | 12:57 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
pulled a rocker stud out the head on my old engine, took the rocker and 2 tappets for that cylinder out and had to drive it to work on 3 down the motorway for ten miles, chuff chuff chuff chuff
Old Feb 8, 2011 | 01:13 PM
chaffe's Avatar
chaffe
good stuff, as said cam and lifters need done together
Bailes1992
Sep 3, 2015 02:17 PM
Tim Wharton
Aug 30, 2015 05:46 PM
borboyous
Aug 22, 2015 11:17 AM
taylora1409
Aug 12, 2015 12:06 PM
