Replacing MFI injectors
Old Jan 17, 2011 | 10:48 AM
kermitt's Avatar
kermitt
Default Replacing MFI injectors
Got myself new ones to fit this afternoon c/w retaining clamps.
I take it will be easier to remove charge pipe and throttle body to get better access.
Then I guess its a case of undoing the pipe from the injector, separating the two and removing the clamps.
Old Jan 17, 2011 | 11:58 AM
stevealien's Avatar
stevealien
10 Year Member
No need to remove charge carrier or tb mate. Just undo the 8mm nut pull em out.
Far left two a bit awkward but simple enough job mate.
Old Jan 17, 2011 | 12:12 PM
sean_rsts2's Avatar
sean_rsts2
addicted to boost
u will probably want to change the seals aswell while your at it.
Old Jan 17, 2011 | 01:15 PM
Karlos G's Avatar
Karlos G
Balls Deep!
+1
Old Jan 17, 2011 | 01:16 PM
c123s1turbo's Avatar
c123s1turbo
I found it's a good idea to wiggle the injector out a couple mill and get a spanner on them as you undo the injector pipe from the injector. I don't think that the clamps hold them tight enough to stop them turn at the same time.
Old Jan 17, 2011 | 03:41 PM
kermitt's Avatar
kermitt
Job done was easiest to remove the throttle body which gave much more space to work with.
Old Jan 17, 2011 | 11:56 PM
aronzvh's Avatar
aronzvh
Hi kermitt, how much are a new set as one of mine are leaking! Is ther better ones to replace em with?
Old Jan 18, 2011 | 12:10 AM
daveandhelenturbo's Avatar
daveandhelenturbo
+1
Dave
Old Jan 18, 2011 | 07:55 AM
kermitt's Avatar
kermitt
Motorsport Developments are selling new ones for circa Ł125 iirc or you can get them refurbished for Ł15 each. Try injectorcleaning.co.uk.
There was someone on ebay selling a new set for Ł100 and another selling refurbished ones who I made an offer to.
Old Jan 19, 2011 | 12:56 AM
aronzvh's Avatar
aronzvh
Cheers!
DixieTheKid
11
Jun 6, 2020 11:20 AM
NZWINRZ
Ford Focus RS
Jan 28, 2020 09:24 PM
steve.rst
Mar 15, 2016 08:01 AM
Chas
Oct 5, 2015 07:13 PM
stevierob
Sep 7, 2015 07:09 PM
