ignition map
Hi lads me and my brother have being messing on with my car today trying to sort the map out. i haven't had a good day with it because i cant think of how to sort a safe ignition timming so i can get the car to idle nice and then start to do some off boost and light boost driving. Its getting to me abit now because i had a idear of what i was doing and i think we know most of what we are doing but i just cant seen to remeber about safe set up part
would be very thankful if you could help me because i cant sleep
Yes mate, it was used to start a 1600CVH. It's actually an ignition map from a T28 powered YB engine. Every engine is different so I and any body else couldn't possibly tell you what kind of ignition your brothers engine will need. Some one like Stu at MSD might be able to give you a few rough figures from experience but they will never be optimal. The way to do it is to find the point of detonation and move the figures back a few degrees (I have worked on a 4-5 degree safety cushion in the past). It will give you a good base to start with and something you can work off. Just get idling, cold start and running, cruising and transients working before you go thrashing it and trying for power.
thanks. i got a base map off a focus rs and was thinking it was a good place to start. the focus ignition table is to retard for my engine because at 1100rpm the manifold starts to glow. il try to post a pic on because my map looks abit diffrent to the maps ive see on here
thanks again lads
thanks again lads
thanks again lads
thanks again lads
You need to get it idling at 14:1 then add some more ignition advance. Not the other way round.
if i'm being thick please tell me, but reading that should put any1 of an evolution chip un less the car was in their hands???
Chips don't really change that much.
An evo chip will probably retard the ignition at higher boost/rpm, remove the boost limit etcetc. or something similar. Its not doing a great deal, its changing something that already works.
A base map isn't safe to start with, won't work really well etcetc, and every engine will require slightly different trims and values for the same spec, no two engines are the same, your not making small generic changes to something that works.
Its likely a base map for one car will work well on another but the final map could look very different.
Rob,
Rob,
plus as bram says, you normally get an rst set up at the same time as getting it 'chipped'. All the chip is letting you do is run more boost before the ecu intervenes.
Rob,
Rob,
Lol, yes i've replied. need to have another peak at yours mate but i guess it looks roughly the same whilst your mapping?
Rob,
Rob,
yeah mate just trying to sort the map and theres some loose ends i need to sort before central day, do you think yours will be done for then and are you going
My statement was meant to indicate that only someone like Stu with experience in varying types of engines and secifications will be able to give you a very rough set of figures.
For example, if I knew that dependant on spec most ZVH engines will comfortably run between 10 and 18 degrees at 25 psi boost at 5k rpm, I'd tell you to run 6-7 degrees as a safety margin. Without pushing it to the point of det, you won't know what figures it will run safely but you can have an educated guess.
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
