efi engine problems
Old Dec 30, 2010 | 09:18 PM
mike s2 rst's Avatar
mike s2 rst
Default efi engine problems
thanks to LOADS of help from peep on here iv had my escort up and running for awhile now and love it
if fact i love it so much iv bought a fiesta rs turbo for some efi fun as i wanted to leave the escort mfi!!
i bought the fiesta as a non runner and have since build up a new engine and fitted it but now i have two strange problems that i cant seem to get my head around so thought u guys might b able to help....
the engine idles fine but when i rev it i am getting a build up of pressure into the coolant system?
as if im loosing compression into the cooling system but the cylinders all have and hold compression and there is no sign of leaking from my leak back tester.Also the cooling system is holding pressure????
the other problem is that it seems to be breathing heavy?
if i remove the oil cap i seem to have to much pressure.
these probs could b linked as they are both pressure related but i cant see where/how the pressure could b leaking?!
any ideas??
also could someone post a pic of where the two pipes go to and from the control valve solenoid that bolts to the air box
thanks in advance
Old Dec 30, 2010 | 10:13 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Sounds like both the rings and the head gasket have gone mate
Old Dec 30, 2010 | 10:30 PM
mike s2 rst
thats what i would say but they are both new??
and iv stripped it and checked them and they seem fine??
and would that not show with the compression test and the cylinder leak test??
Old Dec 31, 2010 | 07:10 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Hmm that's strange, yes they would show!
I take it you didnt reuse the head gasket?
Old Dec 31, 2010 | 08:30 AM
cj_rst's Avatar
cj_rst
S2 RST
Coolant system does run under pressure in normal circumstances, depends how much tho! Make sure it's properly bled or you'll have an air lock which will cause pressure. Also, check the thermostat's ok.
Re the breathing heavy issue - you're always going to get crank case pressure but again it depends on how much. Does it run ok? If you've tested for compression and leaks and all appears to be ok then I'd get it down to a tuner for an expert opinion
Old Dec 31, 2010 | 10:29 AM
mike s2 rst
no i used a new gasket and have also replaced the rings just to be safe!!
Old Dec 31, 2010 | 10:35 AM
mike s2 rst
the problem is when i rev the engine u can see the bubbles/pressure building in the bottle which increase with the revs so it must be compression leaking into the cooling system??
i just cant how
the pressure in the oil breathing is too much to b normal i think!
im just going to check to see if that raises with revs because i think they could b linked!
Old Jan 2, 2011 | 11:36 AM
mike s2 rst
ok iv sorted the oil breather problem (i hope)!!!
iv going to attack the colling prob again today, im wondering if im not bleeding the coolant system correctly?i might take the stat out and run it to try and prove the point?!
also can someone tell me or post a pic of where the pipes go from/to on the sensor at the back of the air box?
thanks
Old Jan 2, 2011 | 02:00 PM
zippyobrien's Avatar
zippyobrien
Disconect the water feed to the turbo. The housing my b cracked letting gasses into coolant
Old Jan 2, 2011 | 08:37 PM
mike s2 rst
iv clamped both in and outlet pipes to the turbo off and it made no diff
but il try disconnecting them completely just incase.
Old Jan 2, 2011 | 09:39 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
So your seeing bubbles in the header tank, and that's the only symptom your seeing of a possible problem?
this is normal tbh unless it's pressurising so much it's pissing out the expansion tank's cap...its jus some froth from the water pump.
Old Jan 2, 2011 | 09:40 PM
cj_rst's Avatar
cj_rst
S2 RST
Sounds like you've just got an air lock in the coolant system, run with the cap off the header from cold, squeeze the top rad hose till you can feel water is definitely in there. Tighten cap up, run up to temp and let the fan cut in. Leave to cool right down and repeat to be sure, should be sorted then
Old Jan 2, 2011 | 10:11 PM
mike s2 rst
no its more than normal pressure!im pretty sure its compression leaking into the cooling system!
at idle its fine but if i rev the engine then it will fill the bottle and blow the cap within seconds!!!
i just cant see how/where the pressure is escaping from!
iv got good cylinder compresion and no leak back
im gona check the turbo again 2moz but im thinking i must hav a crack in the head somewhere???even tho iv had this off and pressure checked!
Old Jan 2, 2011 | 10:26 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Sounds like it could be a cracked head.
Old Jan 2, 2011 | 11:02 PM
liam-rst's Avatar
liam-rst
shit happens
could also be a water pump
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
EoinXR3
Sep 7, 2015 05:44 AM
Dahl88
Aug 22, 2015 08:16 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
marky_g
Aug 17, 2015 12:21 PM
