What realy controls the FAN, HEATERS AND INDICATORS
Old 02-01-2011, 09:15 AM
cosworth_cab
Never over till its over
cosworth_cab's Avatar
Default What realy controls the FAN, HEATERS AND INDICATORS
There is a black looking relay under the drivers foot well, anyone know what this could be for!!! Lost all Indicators, Heaters, Rad fan and reverse lights... Changed the yellow relay under bonnet, still no joy......
Old 02-01-2011, 09:53 AM
luke19790_3
luke19790_3's Avatar
is it for the heated screen, have checked the fuses
Old 02-01-2011, 09:56 AM
cosworth_cab
Nah mate, they all stopped working... They all must work off same relay....
Old 02-01-2011, 10:15 AM
javierant3
javierant3's Avatar
I had same fault two years ago and it resulted to be a relay. It`s a black relay in the main fuse box. It`s under the bonnet.
I think it`s the relé marked with VI (six) in the board. Haynes lists it as ignition switch. Mine it`s an mk2 orion, but I think it`s same as the escort.
Old 02-01-2011, 10:18 AM
cosworth_cab
just checked, I dont have a black relay in my fuse box!!! could it be inside the car!!!!
Old 02-01-2011, 11:02 AM
morph
morph's Avatar
Is this the mk4 rs turbo? which relay did you check? as there are 2 yellow relays in the fuse box 1 for horn and 1 for indicators and lights.
nearest to inner wing is indicators i think.
Old 02-01-2011, 11:06 AM
cosworth_cab
thanks for reply, yea mrk4 rs turbo, i changed both yellow ones!!!! there is a black one under dashboard, any idea wat this is!!!
Old 02-01-2011, 04:16 PM
luke19790_3
do you have a multimeter? i would check that you have 12 volts on the ign switch
you can get cheap ones from maplins
Old 02-01-2011, 10:58 PM
dandannydandan
dandannydandan's Avatar
This sounds a lot like what happened to mine. I'd lost loads of stuff too, heaters, windows etc. When testing the ignition I got 12v in position 1 and then nothing at 2????. Further investigation found a whole bunch of melted wires in the loom. Could of been a nasty fire so it's worth having a good look around in my experience and not jump straight to relays. Oh and I had no warning smells before hand.
Old 02-01-2011, 11:02 PM
cosworth_cab
sorted, put new loom in lol, old one was a mess
Old 02-01-2011, 11:04 PM
dandannydandan
Lol. That's exactly what I did.
mark94
Ford Mondeo Including ST
10-10-2023 06:52 PM
07-10-2015 12:56 PM
Chas
05-10-2015 07:13 PM
fordrallycar
30-09-2015 07:57 PM
stevecfrst1
30-09-2015 05:18 AM
Quick Reply: What realy controls the FAN, HEATERS AND INDICATORS
