Is it worth doing Rear disc conversion on escort rs turbo
Old 29-12-2010, 03:44 PM
cosworth_cab
Never over till its over
cosworth_cab's Avatar
Default Is it worth doing Rear disc conversion on escort rs turbo
Got an escort rs turbo, been thinking about a rear disc conversion or should i stick with the drums?? What would i need too do the conversion too?
thanks
Old 29-12-2010, 03:46 PM
Oranoco
Oranoco's Avatar
imho, No not at all. The drums are quite capable of stopping the car if you look after them. Rear disc conversions tend to cause the rear of the car to be overbraked unless you spend some time on the right bits to set them up properly.
Old 29-12-2010, 03:50 PM
Rsar
Rsar's Avatar
As oranoco has said m8 most of the braking power comes from the front and with a rear disc conversion unless you have a bias valve you run the risc of the back of the car overtaking the front when you brake lol a nice set up on the front is all you need really imo
Old 29-12-2010, 03:51 PM
cosworth_cab
Thats what i was thinking, keeping the drums and adjust them properly.The pedal feels a little bit spongy, dunno if the servo is on its way out!!
Old 29-12-2010, 04:06 PM
Oranoco
Oranoco's Avatar
Spongy pedal would point towards air in the system or master cylinder pegging out. I usually find it to be the former.
Old 29-12-2010, 04:07 PM
darrenb16two
darrenb16two's Avatar
I would say it was a great upgrade if fitted & setup correctly. I love mine and they are spot on but tbh have heard some horror stories of cars spinning when braking hard, how true that is i dunno
Old 29-12-2010, 05:32 PM
Karlos G
Balls Deep!
Karlos G's Avatar
It's VERY true! lol
Stick with drums and upgrade the fronts if you want better brakes, or if you must go rear disc do the front aswell with something really good, I run 300mm FST brakes on the front and still the back locks up first!
Old 29-12-2010, 05:54 PM
Oranoco
Oranoco's Avatar
There was a chap on here not so long ago who wrote his ERST off after a rear disc conversion
Old 29-12-2010, 06:02 PM
studabear
studabear's Avatar
kids rs was 1 person to, his s1
Old 29-12-2010, 08:00 PM
martinmilne
martinmilne's Avatar
i run rear disc and tbh was waste of time and more hassel then its worth they do work now! and improve braking but wouldnt do it again
Old 29-12-2010, 08:47 PM
Puss2
Formerly know as Puss
Puss2's Avatar
I cant understand why people have so much trouble i have rear discs and never had a problem. I have 335mm ap 4 pots on the front no abs got rid of the standard compensators for inline ones and before people say its because i have big brakes on the front i used to have st170 brakes on front
Old 29-12-2010, 09:32 PM
Karlos G
Balls Deep!
Karlos G's Avatar
You have inline compensators, so obviously you have balanced them! Either that or you dont brake hard enough?! lol
Old 29-12-2010, 09:44 PM
johnenright150rst
johnenright150rst's Avatar
Brilliant IMHO,
My setup.
Cossie front calipers and discs
rear cossie discs and calipers
rs2000 handbrake cable
Abs Removed
working rear compensators
Blead properly with load on the rear on dot 5.1
I have very good brakes never had a problem.
My mate on the other hand my setup came off a mates car all the same apart from the fact that he removed the rear compensatiors and was quite sketchy under hard brakeing!
I would wack a bias valve if i had any problems!
oh and the drums look wank imo
cheers john
Old 29-12-2010, 10:43 PM
martinmilne
think its where people fit them to old braking systems with dogey compensators you renewed yours and everything was new and worked this is where my proplem was compensators had seized now freed up working fine
Old 30-12-2010, 07:17 PM
Rob_DOHC
Rob_DOHC's Avatar
IMO i think you would have a hard time fading the rear drums.... unless on track, i never did, faded the fronts plenty (cossy disks and rst callipers), AND the hand brake on drums is loads better.
You'd be better off spending half the money refurbing the standard brake system and properly removing the ABS.
Rob,
Old 30-12-2010, 10:04 PM
Puss2
Puss2's Avatar
So basically rear discs not needed but if you do make sure you ditch the abs and get inline compensators
Old 30-12-2010, 10:12 PM
Rob_DOHC
Rob_DOHC's Avatar
pretty much lol
Old 31-12-2010, 06:02 PM
jonny s2
jonny s2's Avatar
nice little setup if done rite, but tbh if the drums are serviced etc...there more than upto the job, its the fronts which need sorting ideally,disc conversion is great for track use tho
Old 31-12-2010, 06:20 PM
cosworth_cab
Thats wat i was thinking, wat kinda brakes should i consider on front?? There some on ere fro sale the 4 pot hi spec with 300mm discs, any good????
Old 31-12-2010, 06:29 PM
Total waste of time, look at a lot of the hot hatch cars, they disconnect the rear brakes.
The drums as said are way more than up to the job, with the amount of traction you can generate from the very lightly loaded rear wheels.
Old 31-12-2010, 06:43 PM
essexRSTSouthend
essexRSTSouthend's Avatar
I'd like to add,some people might prefere keeping the rs looking standard from the outside.Nothing wrong with oldskol drums, that have no problem doing the job they were built for.
Old 31-12-2010, 06:47 PM
jonny s2
jonny s2's Avatar
ive never used HI- specs tbh but heard mixed opinons, most people highly rate them, and being 4 pots with 300mm discs you wont go far wrong, or maybe use some old sierra 4 pots, or maybe 4x4 cossie jobbies if your on a tight budget
Old 03-01-2011, 10:03 PM
makaveli96
makaveli96's Avatar
I had the rear brake disc conversion done, 4x4 brand new cossie set up along with brand new compensators valves which are set up right, abs removed and up front are almost standard brakes and my rears never lock up under hard braking.
Old 04-01-2011, 11:43 AM
Rogeyboy
Rogeyboy's Avatar
Good Answers, been wondering this myself.
Im on 300mm Fronts with mondeo mk3 calipers, Orion/XR3i rear drums with ebc greenstuff shoes and they r fine. Set the handbrake up so 2clicks locks the rear wheels and they have been faultless!
Old 04-01-2011, 04:51 PM
s2turbsZVH
Will it ever end !!!!!!!
s2turbsZVH's Avatar
Get the rear end refurbed and minty and you wont go far wrong - this is how my rear brakes looked once i tidied them up a bit and now no probs - running 2.1zvh with 4x4 cossie front and standard RS rears.
Old 04-01-2011, 05:27 PM
Oranoco
Oranoco's Avatar
^ Nice. I've never had my drums fail to slow me despite being described by my tuner as being "an animal" (thanks.... I think ) behind the wheel
Old 04-01-2011, 08:45 PM
s2turbsZVH
s2turbsZVH's Avatar
^ Cheers. I must admit i have refurbed the load compensators as well so they move freely as well but all in all now sweet.
Old 04-01-2011, 09:33 PM
dangerousbrian
dangerousbrian's Avatar
i had problems with my brakes after upgrading the fronts and thought it was them at fault..i ended up renewing all parts on the drums and had a noticeable difference..and thats s1 which are smaller than s2 drums
Old 04-01-2011, 09:35 PM
gaz s1
gaz s1's Avatar
ive been on cossie fronts and rear discs for the last 13 years done loads of trackdays etc and have never locked the rears!
Old 15-01-2011, 04:01 PM
burnhamshaun
burnhamshaun's Avatar
right i want rear disc brakes now. I have the rear discs 300mm, calipers, handbrake cable and the caliper brackets what else is needed and anyone in essex that knows what they are doing want to come show me how its done for a few beers of course ŁŁŁŁ
Old 15-01-2011, 05:23 PM
dave_s2_rst
dave_s2_rst's Avatar
I would come if I knew what I was doing lol
I've got rears sitting in the shed (300mm) but can't be asked putting them on, lol.
There's a guide up top "rs turbo" page highlighting what you need to do.
Old 15-01-2011, 05:29 PM
botters
competant bodger
botters's Avatar
only reason i would even contemplate fitting them would be to look nice behind some spokey wheels that you could actually see them behind! seeing as i have standard wheels on mine i wont bother as i find the drums to be perfect for the job therefore disk brakes are completley unnecesary
Old 15-01-2011, 05:31 PM
burnhamshaun
well dude how about we nuckle down and help each other do both cars i dont use mine during the week so we could do mine as a dummy run if you want lol lol where in essex are you im wickford
Old 15-01-2011, 05:33 PM
burnhamshaun
to be honest mate thats the only reason id be doing it which is why any of us change anything on any car we buy id say more than half of what everyone does is for looks anyway
Old 15-01-2011, 05:34 PM
botters
competant bodger
botters's Avatar
true mate
Old 15-01-2011, 05:43 PM
Brendan
struggling with reality
Brendan's Avatar
I have a FRST and I have Cossie 4x4 Tarox disks and ford calipers. on hot summer days with sticky Tarmac I can get the rear wheels to lift off...... The vast majority of the braking is done at the front. so I don't realy see the point of disks at the rear apart from looks.
Old 15-01-2011, 06:03 PM
dave_s2_rst
Not too far dude, near romford. Weekdays are hectic (being a teacher), my weekends aren't free for a few weeks at the moment, so depends how soon you will be doing it dude.
give us a shout beforehand
cheers
Old 15-01-2011, 06:07 PM
burnhamshaun
cheers
omg i work in romford and if thats your car in ur sig i think i saw you last week some time on the a12 heading towards gallows corner at the lights by whalebone lane north come to think of it i also saw a black series 2 by ardleigh green road a12 southend bound that flashed me a couple of months back was that also you
Old 15-01-2011, 06:17 PM
dave_s2_rst
Yup car in sig is mine
defo wasn't me flashing lights but poss me driving towards a12 gallows corner. Theres another black s2 flying around romford on standard wheels ive seen many times as well
Old 15-01-2011, 06:22 PM
burnhamshaun
fair play mate defo see one like yours the other day not sure when but would of been between 3-4.30ish same wheels as urs think it had a show cage but tbh it was quite dark so couldnt be to sure i was in a parcel force van
Quick Reply: Is it worth doing Rear disc conversion on escort rs turbo
