how to fit boost gauge
i guess this has been asked lots before but i cant find an answer on here.
just wondering which side of the inlet do i fit my boost gauge/vacuum pipe too?
my dump valve is on the right (passenger side).
should i t piece the same side or use opposite side?
does it matter?
thanks fellas
does it matter?
thanks fellas
YES I KNOW I CANT SPELL
Yes you can T into the dump valve side will be fine as you want the gauge to show vac as well as positive presure. Dont T into the map sensor pipe tho. I try and keep it so they have one pipe from the inlet to the sensor
mrmann
20-08-2015 11:24 PM
CabrioTurbo
01-08-2015 11:04 AM
