Advice
Best place to buy 10/50 oil from
What is involved and how much would it cost to do a rear disc conversion on my mk4 escort cabriolet also I've got willwood 4 pots on the front but I am after going bigger but I'm on a budget and want to try doing it myself what options do I have and what are a straight fit
don't know about the rear disk conversion bit give oilman a ring at opie oils. he'll recomend you which oil to get and confirm whether or not 10w50 is the right viscosity.
Rear disc conversion can be more hassle than its worth on mk4 escorts. Most people buy brackets to hold the caliper then get saph cossie rear discs and calipers with a mk5 rs2000 handbrake cable.
would it be worth doing this and ho hard is it to do etc also what options do i have with mr front brakes someone said i may be able to use bigger discs with my willwood calipers is this true or bull crap
Sounds good rogeyboy. Was gonna say, couldnt be a rs turbo meet yet lol, mines not been on road for a few years and wont be for another 7months or so yet lol, loads to do still.
If you are going for disks on the back then it may be worthwhile piping in a bias valve. You don't want the rears locking up on you during hard braking and spinning the car unnessecarily.
What power are you running and are these really needed or just for looks?
Any ideas on what the problems could be with them I thought with willwoods they would be sharp snappy and powerful but I have to almost put my foot
Thru the floor to stop I'm thinking of changing for bigger up front but need to know if I can use bigger discs on these calipers as someone said I could but not sure how to find out
If this is true or not
could be to do with the master cylinder mate. Is it a original cabriolet one in there? reason i ask is i got non abs master cylinder and lines in mine but with the cossie brakes i found my foot going to the floor so got a series2 master cylinder and that apparently helps things as its a 25mm compared to the cabriolets 22 or 23mm. Hiope this helps a bit.
try bleeding the lines again or checking for leaks cos maybe a beake pipe has corroded. As i said get it checked first to make sure its ok before moving on to the rear. Is your fluid level topped up to where it should be..
I had them fitted at Jamport and I did noitced a difference straight away as for the fronts I've got standard size tarox g88 discs with ebc pads and in total the brakes are fine. nice cab by the way.
Cheers well Im pretty sure my discs are warped I'm thinking of taking it to kwik fit or some where that do a free brake check and see what they come of with then go from there I guess
mk3ste
17-10-2021 10:09 AM
Mc5506
05-10-2015 09:57 PM
rsguy
44
29-09-2015 03:29 PM
