Problem with reverse lights.....
Old Nov 19, 2010 | 01:21 PM
DanFR147's Avatar
DanFR147
Default Problem with reverse lights.....
I've recently had my ERST engine rebuilt. However since i've had the car back I was told that my reverse lights no longer work! I've been under the car and played with the 2 prong plug which conneacts to the gearbox but they still don't work.
What else could it be?
Old Nov 19, 2010 | 01:40 PM
s1cab's Avatar
s1cab
when you say played with ? do you mean jumped the switch?
Old Nov 19, 2010 | 10:11 PM
DanFR147's Avatar
DanFR147
Thanks for the interest s1cab. Jumped the switch? All I've simply done is unplugged the switch and cleaned the connections etc.
Old Nov 19, 2010 | 11:21 PM
s1cab's Avatar
s1cab
put a wire jump between the two pins on the plug, put the car in reverse with ignition on and check the reverse lights. sounds like the reverse light switch in the gearbox is busted.
Old Nov 21, 2010 | 09:31 AM
DanFR147's Avatar
DanFR147
Hi mate, tried this but still doesn't work.... I just don't know what else it could be?!?!
Old Nov 21, 2010 | 09:38 AM
studabear's Avatar
studabear
bulb?
Old Nov 21, 2010 | 04:51 PM
DanFR147's Avatar
DanFR147
Originally Posted by studabear
bulb?
That was the first thing I checked!
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
