Head Gasket
Coyote
Hi people,
just been inspecting a new head gasket to put on when i change this cylinder head over as i managed to rip the no.2 inlet rocker stud out the head while driving
, anyway, my car gets hot very quick while stationary, but cools down nicely while driving, but on the cylinder head, the water ways are pretty large, same with the block, but on the head gasket (genuine ford item) the waterway holes are only about 3mm holes, surely this cannot be right, or should it be like this?
![](http://i52.tinypic.com/wlu0c1.jpg)
ive tried to circle the little holes for waterways
![](http://i56.tinypic.com/25ahlqv.jpg)
and circled the waterways.
just wondering more than anything
cheers
cheers
Coyote
Cheers for the replies guys. I don't run a thermostat in mine as it gets pretty warm quickly, and fan switch is still a standard one so could do with a lower degree one and see if that helps out. For the temperatures of engine I'm hoping there's a block in the cylinder head or something, otherwise I have no idea what it is
however them holes in the gasket do seem to be abit naff to let water through, but if that's how its designed it should work fine
Cheers for your help
Wye Valley Hardcore
Thats correct. The holes small to create pressure in the system as the water has to be forced through the holes. Also if the holes were really big and the water flowed through quickly it wouldn't absorb the heat. Same way as the thermostat opens and closes.
Wye Valley Hardcore
Also it makes sure that the whole system is fed with water. If the holes were huge and the water was pumped into the top right hand side of the head it wouldn't get water to the back left of the head and block.
Coyote
ahh okay that makes sense then.
what could cause the engine to get hot, as in, gets to the red within 5 minutes of sitting in traffic or lights. driving conditions just goes under the M on NORM which im happy with, but then come to a stop, have to put the heaters on full whack to try and take heat out. could it be that the engine is running rich? as i understand this can cause high temperatures. definately not running lean with the amount of fuel and flames it pops on its own. could wrong grade of oil cause it? using running in oil at the moment as its a fresh engine, so that will be changed to something like 10-50 when i change the head. there are no blockages in the block, but not sure about this head on at the moment. the fan definately kicks in, but could do with coming in earlier.
any suggestions i can check out?
Martin
Martin
Wye Valley Hardcore
I would have thought running rich would make the engine run cooler as the excess fuel cools the bores. Running lean would cause it to run hot, as mine did.
What condition is the radiator in? What fans are you using? Fans on intercooler setup?
Coyote
i would of also thought that running rich would allow the engine to run cooler, but i read somewhere that it increases the exhaust gas temperatures or something, and thought that the head could leak through onto the rad being so close (about 2 inches away)
the radiator is in good nick, still the original, no cracks, no leaks, all fins are in tact, as no blockages as far as i am aware, however to to certain on this, but it used to run cool before changing the management.
The water pump is in good condition, although am going to change it as a matter of course.
using a single kenlowe fan, although setup of it is abit weird.
because when we installed the full front mount intercooler(grs) i wanted the fan inbetween the rad and intercooler, which is how i had it before, but the radiator was on a huge piss and just looked crap, was also nearly touching the turbo wastegate backet, so thought id change it around, so have the radiator further forward, and have the fan on the back of radiator. it is not possible for me to have the fan on the front of the intercooler, next to the bumper as there is literally no room at all, maybe 20 mm at the most, and without cutting lumps out the bumper the fan would not fit.
we tried the radiator in its orginal place, and the intercooler as far back as it gets, and then the fan, but the bumper still wouldnt go on with cutting it up to allow the fan to fit.
i think this could be the problem as the fan i dont think is doing much, just sucking hot engine air and pushing it through the rad, and even if i switch the wires, it hasnt got enough suck to pull the required air through.
i was thinking of putting the radiator back in its original place, pushing cooler as far back as it goes and then hollowing out the bumper and see if i can squeeze it in then, or if that fails then i have no idea lol![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
Martin
Martin
Coyote
could be right there you know. but would that explain the engine temps rising fast when in traffic? literally from just under M on NORM, to just under red takes 5 minutes maybe abit more.
Wye Valley Hardcore
Fans are either suckers or blowers due to the design of the fan blades. Although your Kenlowe will work reversed it won't be working to full efficiency because of this. Thats why kenlowes have a sticker on the top saying ROTATION and an arrow. a Single 10 inch wouldn't be enough anyway I wouldn't have thought.
try makeing the fan spin the other way and see .... if not sounds like you need the right fan...
and also while your there get the msd fan switch and thermostat its the best mod i have on my car i think.... its the one thing i noticed a massive difference and was like £35 delivered
07-10-2015 12:56 PM
Mc5506
05-10-2015 09:57 PM
