running issues
Old Sep 29, 2010 | 10:57 PM
diamondrst's Avatar
diamondrst
Default running issues
changed the head on my s2 today now wen i start it it starts and runs really lumpy sounds like its misfiring could the timing be out slightly would it cause this problem cheers
Old Sep 29, 2010 | 11:17 PM
OLDSKOOLRYAN's Avatar
OLDSKOOLRYAN
yes check your timing, try adjusting your dizzy
Old Sep 30, 2010 | 12:32 AM
rsmark86's Avatar
rsmark86
best way to do the timing is...
remove the cap and rotor arm and flash gaurd then put the rotor arm back and in the middle is a line ... and on the dizzy on the outer edge (the thin bit) is a little slit just line these up and tighten dizzy back up .... then refit flash gaurd and rotor arm and cap then timing should be fine
JK12
33
Apr 26, 2021 12:09 PM
Nov 3, 2015 04:08 PM
xrmalin
Sep 13, 2015 06:52 PM
gingeRS
Sep 4, 2015 06:29 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
