2 stage boost?? how??
Old Sep 29, 2010 | 10:30 PM
rosie's Avatar
rosie
Default 2 stage boost?? how??
how do u wire up/set up a 2 stage boost on a rs turbo??
if i remember right u have 2 cut intp the green/brown wire from amalvale & put a switch inline????
& set boost up to say 14psi on actuator with amal valve wired up/switched on???
that correct??
how does it know what boost 2 run when amal valve is switched off?? say 10psi??
Old Sep 30, 2010 | 06:02 AM
chaffe's Avatar
chaffe
Turbocharging Technician
You can use the amal valve for two stage boost. What to do is set the actuator at your lower level, say 10 psi. Then with the amal valve off (not live) you will run 10 psi, as you are bleeding no air off. Then if you switch the valve on you will be bleeding control air off to the actuator ( the same way a bleed valve does) and you will run a higher boost level. This level (ive found a bit of experimenting helps) can be controlled by the size of restrictor you have in the vent port on the amal valve, it will ahve to be quite large for a big differential in boost levels (approx 3mm for 7psi). Hope this helps mate.
Old Sep 30, 2010 | 08:13 PM
rosie's Avatar
rosie
cheers mate, & its just the brown/green wire that has 2 be switched?
im sure on the amal valve the top pipe should run to the actuator & the middle pipe to the turbo houseing???
on mine its the other way around so i'll have 2 swap that back over 1st as it isnt right
Old Sep 30, 2010 | 08:24 PM
chaffe's Avatar
chaffe
It just needs an earthand a live. The Amal valve has marked on it,W,C,A for wastegate, compressor andairbox
Old Sep 30, 2010 | 08:27 PM
martysmartie's Avatar
martysmartie
Exactly as he ^^ said
There are three outlets (W) goes to actuator the middle one (C) goes to the compressor housing and the third (R) is the bleed outlet and originally would have gone to airbox but seen as most have induction cones etc the hose is usually removed.
It's the earth wire you cut which goes back to the ECU as you say, don't know the colour on RST.
Martin
Old Sep 30, 2010 | 08:36 PM
chaffe's Avatar
chaffe
Usually saab valves I've used, two seconds with a meter would have it sussd though mate
Old Sep 30, 2010 | 10:52 PM
rosie's Avatar
rosie
thanks for ur help, ill get on it 2morra
cheers
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
Russ Payne
Sep 25, 2015 08:29 PM
