Things getting a bit warm!
Old Sep 26, 2010 | 12:49 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Exclamation Things getting a bit warm!
CPS plug...
The heat shields that were fitted from factory, do they cover this as well as the starter?
I've decreased the on boost timing by 1deg and increased the fuelling slightly too, there is no Det and it wasnt lean but things are obviously a little too hot lol
Old Sep 26, 2010 | 01:00 PM
studabear's Avatar
studabear
bloody hell karlos, how did ou spot that, none starter?
Old Sep 26, 2010 | 01:02 PM
andy130's Avatar
andy130
jesus lucky there, could have cause some damaged,
Old Sep 26, 2010 | 01:20 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah it struggled to start the other day, stuck the lappy on and had a erratic RPM signal (so no spark), unplugged the CPS observed the plug, back on and it started fine.
Replaced the plug with a brand new one just now.
Old Sep 26, 2010 | 01:51 PM
studabear's Avatar
studabear
my pile of crap struggled to start this morning, well went onto 2 cylinders and wouldn't rev, eventually found no pulse to injectors 1 & 4, well that was at 5:45am, couldn't do much more with the neighbours
Just been and had a little look, started on 4 and appears to be running fine again, its getting close to breaking point
Old Sep 26, 2010 | 01:54 PM
Karlos G's Avatar
Karlos G
Balls Deep!
At least thats a bonus of running aftermarket management, I can just plug in the lappy and see whats wrong, or at least eliminate a few things right away!
Old Sep 26, 2010 | 02:06 PM
studabear's Avatar
studabear
I'm gonna get monitoring software sorted out
Old Sep 26, 2010 | 02:22 PM
DazC's Avatar
DazC
Had this with AJC's red RS1600i but fortunately it never got hot enough to melt completely despite having it's head kicking everywhere.
I put a sleeving on the wire to protect it but that ended up melting. The main plug and harness remained fine though. Never got chance to give it any protection as he sold it on.
Old Sep 26, 2010 | 02:53 PM
Karlos G's Avatar
Karlos G
Balls Deep!
I think it'a probably because my little stage 2 T3 is flat out and so get a little warm lol
Old Sep 26, 2010 | 03:00 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Just looking at getting some heat shielding and spoted this...
Then pissed my self at the description....
"Increases horsepower
Reduces turbo lag
Reduces under bonnet temperatures
Simple Installation "
lol
Old Sep 26, 2010 | 03:45 PM
rsmark86's Avatar
rsmark86
wheres that from .... ripspeed lol
Old Sep 26, 2010 | 03:52 PM
Karlos G's Avatar
Karlos G
Balls Deep!
http://www.priracing.com/section.php/399/1/turbo-shield
Ł160 too!!
Old Sep 26, 2010 | 03:54 PM
rsmark86's Avatar
rsmark86
Originally Posted by Karlos G
160 for a more responsive engine and more power got to be a best buy lol
and if you buy the ripspeed sticker to match you will gain another 10 brake lol...
Old Sep 26, 2010 | 04:10 PM
DazC's Avatar
DazC
The reason why they claim the extra response is due to increase thermal efficiency by keeping more energy (heat) in the turbine housing. However they usually lead to housing prematurely failing due to heat stress (cracking) as the heat struggles to escape. It does help response to a certain degree but once the turbo is up to temperature it makes no difference as the heat is already there, and anyone who has had a turbo bright red will know how long they take to stop glowing! Extra horse power is bullshit though.
Old Sep 26, 2010 | 04:18 PM
billybob's Avatar
billybob
i see these advertised on ebay from a place in the usa i think they where about Ł60, was tempted to buy 1 as my combivan with t34 over heats in traffic and wont boost properly warm weather
Old Sep 26, 2010 | 04:19 PM
12_Second_rst's Avatar
12_Second_rst
In theory tho lower intake temps increases hp so if u can lower your underbonnet temp thus lowering intake temps????
Probs hardly noticable gains tho
Old Sep 26, 2010 | 04:37 PM
gus's Avatar
gus
i thought turbo blankets were a bad thing
i know they are used in motorsport alot
but
they have a bigger budget then you and i
Old Sep 26, 2010 | 04:47 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
I can't stand the stuff but can't ya heat wrap the downpipe, are you running a zetec bottom end with tubular manifold cos it puts everything offset so closer to the cps
Old Sep 26, 2010 | 04:49 PM
gingerturbo
There's a really gd place in lakeside that ceramic coat manifolds and turbo to keep the heat in which helps a lot with the engine bay temp and bhp, but costs a far bit to do
Old Sep 27, 2010 | 06:39 PM
JesseT's Avatar
JesseT
The original AMP connectors can easily take the heat, the cheaper copies tend to melt when used in the CPS location.
Old Sep 27, 2010 | 06:47 PM
Karlos G's Avatar
Karlos G
Balls Deep!
It was a plug from somwhere else on my old MFI loom so I guess it was an original? But the one I've just fitted is an AMP branded plug.
JoeyBoyden
Jan 4, 2024 02:36 PM
muffster
13
Sep 3, 2015 09:40 PM
YODI
Aug 29, 2015 05:48 PM
Roosie
Aug 13, 2015 07:40 PM
