priming new turbo
priming new turbo
while I'm putting my car back together I'm following these instructions from the turbo builders
FOR CORRECT TURBOCHARGER INSTALLATION
In order to avoid any possible damage while installing your turbocharger or premature operating problems, either of which could invalidate the warranty, please follow these instructions carefully and completely.
1. Check very carefully that there is not foreign material in either
the air intake or exhaust system, even the smallest fragments have
the potential to cause serious damage at the high operating speeds
of the modern turbocharger.
2. It is important that the turbocharger centre, turbine and compressor
housings are correctly orientated before final fitting. If the bolts,
lock tabs or V-bands are loosened to achieve this, check that all
mating flanges are correctly reseated and that all service manual
torque settings are adhered to when making final rigid connections.
3. All the relevant air, oil and exhaust gaskets should be replaced when
the turbocharger is fitted. It is important to use the correct new gaskets
in all cases, and never use sealing compounds at any turbocharger oil
connection.
4. The engine oil and filter should also be changed, using oil that
is specified for turbocharged engines.
5. Before connecting the turbocharger oil feed hose it is essential
to check for any restriction resulting from oil carbonisation, then
fill the oil inlet port to overflow with clean oil.
6. Crank the engine (without firing) until there is a steady flow of
oil from the drain port before connecting the oil drain hose.
7. Let the engine run at idle speed for a minimum of 3 minutes after
installation. This will prevent possible damage to the bearing system
due to oil delay, and have the effect of purging the system of any
residual contaminants.
Anyway, I'm at stage 6, how long should i have to crank the engine for to get the oil upto the turbo feed?
I have also fitted a new oil line with inline filter, and the sump was off the engine for a week or so, so its well drained, the oil has been refilled with new mobil 1, and I filled the oil filter with oil before replacing.
The car is still jacked up onstands at the front, would the car be better off level?
The battery didn't have loadsa life in it, but we flattened it trying to get oil upto the turbo.
Any hints or tips?
Should the oil light go out just off the starter motor?, I 've still got all the crank and phase sensors unplugged
connection.
Any hints or tips?
tried it both ways, wondering if it to do with the filter? Think I better work back to the T piece on the back of the lock to start with
Balls Deep!
Yeah remove plugs to take strain off starter and allow faster cranking, then crank in 10 second bursts for maybe a minute.... if you have an oil pressure gauge you will see the pressure peek at around 80-90psi (on a stock pump), at this point you know oil is round the whole engine (or at least it should be! lol), if you really want you can pull the oil return hose off and see that it has oil passing through it then you know for 100% that the turbo is primed.
Refit plugs and fire up!
competant bodger
Defo doesn't seem right, its never had any oil pressure issues, it was fine when I took it off the rd, i've replaced the head gasket, sump gasket and it has a new hybrid turbo
oil was drained for about a week, while it sat with no sump on it, its now re filled to just over max, can't see why the oil pump would just stop working, although not impossible
I'm wondering if I could take the oil pressure relief valve out and back fill the pump with oil?
Sorted it now people, its running again, just need to re wire the twin fans, then trim the bumper to clear the intercooler and its good to go, I hope
i dont get why people feel the need to take plugs out when turning a engine over. there is no way it can do any damage to the engine or starter motor.
JK12
33
26-04-2021 12:09 PM
