Which boost controller
Old Aug 26, 2010 | 12:38 PM
mr_joe0606's Avatar
mr_joe0606
Default Which boost controller
Am looking at getting boost controller which is best one to get and will they work on mfi how do you fit them.
Cheers joe
Old Aug 26, 2010 | 01:50 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Amal valve what your car comes with from the factory is great why change it?
Old Aug 26, 2010 | 02:03 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Different boost settings for track/road or wet/dry, gear based boost control for aiding traction in the lower gears, rpm vs boost mapping for eliminating boost spikes and boost drop off at high rpm, scramble boost a bit extra when you want/need it, etc.. etc... lol
Cheers joe
Apexi AVC-R is what I use mate, great controller but it is expensive, and yes all the functions work on an MFI car!
Fitting.. follow the wiring/plumbing diagrams and it goes in place of your Amal valve (bleed valve if you have one fitted).
Old Aug 26, 2010 | 02:38 PM
mr_joe0606's Avatar
mr_joe0606
So on the amal valve will i use all 3 pipes that go in to it or do i need to block any n i have about £200 that can spend on one.
Cheers joe
Old Aug 26, 2010 | 03:28 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Depends on the controller, on my Apexi for example I could use all 3 if I were still MFI.
£200 is about £300 short of an AVC-R, but there a plenty of cheaper BC's that will do the basics for that sort of money.
Old Aug 26, 2010 | 03:31 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
gizzmo MS IBC is what you're after joe, i run one on my xr2 turbo zvh and works well, easy to fit, easy ish to setup.
cost about £200, if you wanted to see mine you'd see how easy it is to setup and fit.
Old Aug 26, 2010 | 03:42 PM
mr_joe0606's Avatar
mr_joe0606
The wireing i would be fine with. Just wondering About the pipe work to the amal valve and how that end works.
Cheers joe
Old Aug 26, 2010 | 04:08 PM
Rob_DOHC's Avatar
Rob_DOHC
Hello mate, you loose the amal and follow the instructions lol, a solenoid sits in the amal valves place and has clear markings telling you what and where every thing goes.
I have a Gizzmo too, but i haven't got an engine so couldn't tell you how well it works lol
Rob,
Old Aug 26, 2010 | 04:22 PM
mr_joe0606's Avatar
mr_joe0606
Lol cheers pal i would off bought one today but paypal are saying i have hit my spending limit and need to get verifid 2-3 working days lol
Thanks for the info guys
Old Aug 26, 2010 | 08:37 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
piping is a piece of cake felle, take amal off and blank the pipe to metering unit.
the remaining pipes go to actuator and compressor housing on turbo, they connect to the solenoid on the Gizzmo IBC.
wiring is easy as said as it's only needing a live feed from ignition and an earth, the rest is already fitted within a loom ready to go.
Old Aug 26, 2010 | 08:58 PM
rstdave's Avatar
rstdave
I've got a nice greddy profec b boost controller for sale on here in your price range mate.....was perfect on my rst, more flexibility than an amal vavle imo, mostly as karlos said above
I loved mine as it was fairly simple to use and did exactly what i wanted...stable boost!
Old Aug 26, 2010 | 09:07 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Any word on your Clutch Dave, is it out mate?
Old Aug 26, 2010 | 09:10 PM
rstdave's Avatar
rstdave
Oh shit, sorry mate forgot to send you a message....it's not but i'm picking a crane up on the weekend so will get the bottom end out so i can have a look! Due to various reasons i have been a bit slow sorting things out but will give you a shout over the weekend
Old Aug 26, 2010 | 09:14 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Ah top man!!
Thanks!
Old Aug 26, 2010 | 09:22 PM
mr_joe0606's Avatar
mr_joe0606
How much are you looking for it fella??
Cheers joe
Old Aug 26, 2010 | 09:39 PM
mr_joe0606's Avatar
mr_joe0606
Just seen your advert rst dave very tempted whats the wireing like? Because the gizzmo ones its as xr2wishy says 12v ignition and a earth.
Cheers joe
Old Aug 26, 2010 | 09:42 PM
rstdave's Avatar
rstdave
Cheers joe
Wiring's straight forward, comes with its own wiring loom that goes to thw solenoid in the engine bay, then you just need to feed the unit with the ignition live/ground. Bit nicer looking than the gizzmo's imo, they look a bit cheap but all do the same job really!
Old Aug 26, 2010 | 09:49 PM
mr_joe0606's Avatar
mr_joe0606
I will have it off you mate then. i would pay with pay pay but its not gona be working for a few days. Will pm you tomos mate.
Cheers joe
Old Aug 27, 2010 | 12:17 PM
mr_joe0606's Avatar
mr_joe0606
I have one more question lol. How should i set my actuator as its running 15 psi at the moment or do i not need to touch it as the controller will sort it all out.
Cheers joe
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
