Had my car set up at Oddkidd's on thursday (thanks for doing that with no notice at all jan) and after a proper bit of enthusiastic driving home one of my already lazy tappets decided to take a turn for the worst, its proper knackerd now. Im going to get a cam kit next week but not sure which one to go for. Do hydrulic tappets have a limit to what power they can take? Was gonna go for a kent cam kit as i already have the pully but they all seem to be hydrulic? Hopefully my car will be a fair bit over 200bhp in the not so distant future when all done so done wanna have to replace the cam again then. Any advice? Thanks
I always stuck to my guns with Kent despite there rep and also the first newman cam i had (hydraulic) killed my engine thanks to a bad grind equalling zero oil pressure!!! However i recently gave Newman a second chance and went solid and my god, its transformed the car! I still say Kent are good if you run it in 100% properly and fit it using graphogen etc but Newman have a v.good range out there now
No way?!
A mate of mine just had a Newmans kill an engine because it fell apart, and then the replacement they sent was shit too having both ends open allowing the oil to piss out the dizzy end resulting in no oil pressure!
They also sent him a set of used lifters with it!!
On 3rd cam now and it's as it should be and came with new lifters.....
They also threw in a Vernier pulley and £80 to pay for new shells, still not really the best though is it?!
bllody hell karlos, thats a pain, glad I put a standard item in mine now, just took the lifters out today, after 500 miles it looks fine.
Yeah I'm glad it wasnt mine...... poor bastard!
To answer the OP's question..
There is no BHP limit as such just RPM for hydraulic, 7000rpm is fine with Hydraulic on standard springs which is plenty for most of us.
well ive got a piper fast road cam in mine it seems mint the worst bit about them is the valve springs you get in the kits are crap so get some desent springs like doubles or something
Do not use doubles, standard Ford springs are fine for well over 7000rpm, as botters says below your putting extra strain on a already weak setup!
Originally Posted by botters
you dont want to go too hard of a spring tho or you will put too much strain on an allready badly designed weak valvetrain
Spot on!
well thats crap because i brought a set of doubles to go in lol
i only got them because my old s2 ran at 23psi and it got realy bad valve bounce on the road and i fitted doubles and it was great after but i surpose i didnt have it long as i sold and built my old mk2 escort lol
Dont matter if you have rollers rockers and solid lifters used with double springs and light weight caps.
Yes but I think it's only YOU who has that setup! lol
Mate i never got valve bounce on a shitty OEM spec cam, springs and lifters @ 7000 RPM, so i really doubt that you would with piper springs (unless they were wanky).
Any one got any thoughts (apart from wearing quickly) on piper cvh34 cams?
What RPM where you getting bounce at then??
it started around 5500rpm but only seemed to do it from 3rd onwards but it was alot worse on the road so i swapped to doubles and it pulled the 20/21psi to the limiter . but i had piper valve springs to start so hadnt tryed the ford ones
Rob,
well it was chris tod who told me that piper springs are wank apprantly its the new springs they do and that the old ones were fine ....
