Mixture Screw
Old May 26, 2009 | 10:51 AM
AJ_ERST's Avatar
AJ_ERST
Default Mixture Screw
Went to adjust the mixture on the metering unit and it looks like the hole for the allen key has rusted away is there anyway of replacing or repairing, or is it just a new metering unit
How far down the tube is the screw, just thinking dirt might have got inside the tube as it had no bung on the tube.
Old May 26, 2009 | 03:34 PM
Marc LJX's Avatar
Marc LJX
Take the little tube off the metering head (secured by two socket cap screws) and try to free it off.
Its like a spring loaded allen key in the tube, so should push down and spring back and turn in both directions easily. Take it off and soak it in WD40 overnight and then have a go at freeing it off. If someone has tried too hard to turn it, the allen key socket may have rounded. All you need then is a new little tube, not a full metering unit...
Old May 26, 2009 | 09:20 PM
AJ_ERST's Avatar
AJ_ERST
Thanks for the advice took the tube off and had a good look at it, its well seized and allen key hole is rounded off.
Think the metering unit is well past its sell by date, took one of the injectors out whilst turning it over and the fuel was coming out like a jet wash
Old Aug 15, 2010 | 11:35 AM
dannyt313's Avatar
dannyt313
hi did you get this sorted as mine doing the same just flooding ((
Old Aug 15, 2010 | 12:20 PM
Chopshop85's Avatar
Chopshop85
Mine had the same problem whilst at the tuners. We ended up just drilling it out and finding a slightly bigger screw to replace it.
Old Aug 15, 2010 | 03:27 PM
dannyt313's Avatar
dannyt313
the injectors are like a jet wash (
Old Aug 15, 2010 | 08:07 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Go to the breakers and look at mercs audi's saab's etc. Loads of motors will have them.
You can mod the metering unit by drilling and tapping a new thread and using a bolt to cap it off instead.
Or just buy another adjuster.
Old Aug 16, 2010 | 06:40 AM
dannyt313's Avatar
dannyt313
ive turned fuel pressure down and got it running but still black smoke out of rear and plugs sutting up(
Old Aug 16, 2010 | 01:54 PM
Versus_Creations
Ask me a question!
You shouldnt be touching fuel pressure as this is set at the correct amount for the injectors to work correctly. Only increase for high spec MFi engines even then not by too much as it will effect the whole rev range.
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
Flatlinedan
Sep 18, 2015 12:41 PM
Fudgey
Sep 17, 2015 01:06 PM
hopper350
Sep 4, 2015 12:53 AM
muffster
13
Sep 3, 2015 09:40 PM
