zetec turbo questions help
guys in the know please help.....
a mate of mine is selling a zetec turbo set up realy cheap and im thinking of getting it for my next project....
its a 2lt silver top with the following work done
calibra pistons skimmed with valve cut outs
standard rods and crank (fully balanced)
arp main set
silver top head modded for cvh manifold (exhaust) complete
bottom end needs assembling with tensioners and belt ect but comes with zetec pullys top and bottom .... it still needs the oil return putting in and the breather blanker plate....
so it needs cam belt / tensioner/ alternater pully/ gaskets/ head bolts/ better valve springs / sump / and breather fitting ...
it comes with a crackle black rocker cover..
he want £250 for it all is it worth it and how much more would need to be spent
thanks
arp main set
thanks
YES I KNOW I CANT SPELL
also can you tell me what you mean by properly??? i no of a 330hp zetec with the same bottom end!!
thats a good price, even if uncomplete. iv heard standard zetec rods take jus over 300bhp
aslong as its got arp bolts. id av thort another £300 and it should be complete.
Ask me a question!
do it right do it once.
Rods and pistons. New bearings gaskets pump etc etc. Done.
Cut corners now and it will bite you back when you least need it when funds are low and you will be less an engine and down loads of labour and expense on an engine that might let go.
I have seen many dead ZT's, built on a budget without spending a little extra in the first place
I have seen many dead ZT's, built on a budget without spending a little extra in the first place![Sad](https://passionford.com/forum/images/smilies/icon_sad.gif)
but all the parts listed above are for sale in the rs turbo section as if im going to build a zetec turbo i want it to be able to take aleast 350bhp with out any trouble
its GRAYZO SELLING UP hes got a few nice bits
i was looking last night and its either abit over a grand to built a pretty good bottom end with rods and pistons ect or just save and buy a mk1 frs head and bottom end then build around them ....
