Battery Light stays on constantly
with a meter should read about 13.5volts, if it is sounds like the wire for the
battery lights has a break in it.
hope this helps
as above the thin blue wire from the alternator if its broken or not connected the battery light will stay on, examine it all the way back as they tend to break in the strangest places
The blue wire is an earth from light so if disconnected the light would EXTINGUISH when connected it acts as an earth hence the light comes on, it also does another important job by exciting the field windings, this starts the charge process. When running this has 12V plus from the alt and so now is not acting as an earth anymore, as two lives the bulb will extinguish, unless of course the not charging.
Is the replacement alternator definantly a known good working unit?
If so I would check all earths particually the engine earth strap.
Even with the light on when running the alternator can still work fine in some cases, if so you will have 13V plus at the battery with the engine running, if not it's not charging, it's nothing to do with the battery.
Martin
Martin
The blue wire as I say above is an earth for the bulb so it will connect to dash.
The fact the bulb illuminates shows that the blue wire is not a problem, it doesn't extinguish however which does indicate a charging problem, first thing I would do is check the output at the battery with the engine running, if +13V then it is actually charging as it is possible to be faulty but still charge ok.
Only other thing it can be is if this blue wire has shorted, again if you disconnect the blue wire from alt and the light EXTINGUISHES this can be eliminated.
Also never overlook the obvious, is the drive belt tight?
Martin
Martin
Martin
Martin
Ok i have disconnected the blue wire and started the car, the light is still on, all i have to do now is check for breaks in the cable etc?
Yes check for breaks as you have a SHORT in the cable as with the wire disconnected the light will not illuminate, trace the wire back through the bulkhead and see if it's chaffed anywhere. It should connect onto the D terminal, the B+ is the output to the battery.
You will find if you rev to around 4000RPM it will charge, at the moment it won't be as the bulb is part of the charging circuit.
W is not used this is used for rev counter on diesels or for chokes in some cases.
Have you had the dash out recently as you may of trapped the wire etc?
Martin
Martin
Hello mates,
I got about the same problem with my ERSTS2 -88. Battery light keeps on glowing red all the time. When I turn the lights, heater, stereo on the light just comes brighter.
I measured it allready and with idle I got 13,65 (lights and heater on) and without ignition 13,02.
I suppose that alternator is ok, so is the thin blue wire from alternator is worn? Any ideas, anyone? Thanks!
Probably a problem with the thick B+ wire, or the connection on the alternator or battery.
Could also be a problem with the diodes inside your alternator.
155lee
06-09-2016 11:10 AM
The Enigma
12-09-2015 10:12 PM
