Rs turbo shaking steering and almost everything renewed.
Basic problem is that when i drive motorway speeds car shakes so badly even that steering column shakes up/down and it feels badly in steering wheel. Altough car does not shake when braking.. (miracle in rs turbo).
Normal driving shaking is so bad that i can feel it in the car chassis when put hand in the dashboard or something and everything vibrates.
Shaking is different depending day, sometimes almost nothing and sometimes so horrible you cant drive car cos everything shakes.
2 different sets of wheels tested, different combinations. Nothing help.
There is slight play in the steering rack and it makes klonking noise when quick turn steering in place.. There is old parts only the steering rack and those parts where bearings are installed , i dont know word for english.
New parts front
-Koni sport shocks
-H&R Springs
-Wheel bearings
-Front hubs
-TCA´s & ball joints
-all steering joints
-Brake discs
-Brake hoses
-Brake pads
-Steering rack rubbers
-Powerflex bushes all front
Ps. i think my car would go to shed under the blanket for several years if i dont find out what causes that. I am pretty finished with this thing.
New parts front
-Koni sport shocks
-H&R Springs
-Wheel bearings
-Front hubs
-Brake discs
-Brake hoses
-Brake pads
rs turbo from Greece...
did you check the plastic item(i don't know how to tell it in english...)between frnt alloy rims and hubs? If these doesn't fit exactly, car is shaking like crazy...
"my steering rack on my s2 had slight play and it shook like fook! so put a new one on it was the best £20 ive ever spent it no longer shakes and the steering is so much lighter than it was before as well"
Well worth £20 after the list of stuff above
Many thanks mates! My steering rack has really bad "play".. it makes klonking sound when turn steering wheel quickly in opposite directions. Car shakes wheels in the corners and in the straight, basically no matter if there is throttle or not or gear in or not. Whole car chassis shakes and car is really bad drive in corners. Maybe one of the worst cars ever which i have driven. So maybe its time to buy patten steering rack for 79€, i have to order it from Germany. I think the driveshafts are okay.. there is no play or extra noices. Now i have working LSD unit and car has about 270bhp and it pulls really badly left / right and it is real struggle to keep it straight line, without lsd it went pretty straight is this normal? =)
let me know if you want one.
Balls Deep!
yep, i would be interested original steering rack but my rs turbo is lhd version.. Can you help?
Karlos: Okay.. it feels pretty wild to drive, maybe i decrease my maximum boost... so it would be less scary.
Ask me a question!
Bush at the bottom of the column.
Noone ever checks these and always crack in half when people change steering wheels etc.
Make sure its in good condition.
The way to test is if you can pull the steering wheel towards you when sitting in the drivers seat then its foooked. . Taking it out is not hard and should be looked at!!!
??? what? of course they are different you plank the steering wheel is on the other side of the car lol
And Jano i was about to suggest the same think, the column has several bushes up its length. My car had the exact same problem, and when i took the column out all the bushed/bearings were awful. But if you have play in the rack there is no harm in changing that first!
Good luck
Rob,
Good luck
Rob,
Rob:
All those plastic bushes, wearing parts are pretty new in the column. Only the steering knuckle joint is old because i cant find new part anywhere. Ford sells only the whole axle including the joint.
i will see if the steering knuckle is available and if yours is a genuine ford rack then you may want to send that off to get refurbed as the pattern ones are sometimes not that great. if you cant get it refurbed over where you live then send it over here and i will get one in fact i will ask if i can get the lhd rack.
Even if it would fit in, the car would steer left when the wheel is turned CW and vise versa.
Rob,
Antti O, sorry for the thread crapping going on mate, its got nothing to do with your problem, but some peeps dont get that!
i have asked the supplier if he can sort out a rack for your car.
he will let me know sometime tomorrow so will get you cost and postage you may not need to send your rack over either.
How very kind of you to apologise on behalf of me Morph.
Any luck with fixing it Antti? Got me thinking i may need a new rack too, Fancy giving me a quote Morph..... that would be for a RHD. Who is your supplier by the way? its not www.itakefordracksandfuckthem.com is it?
Rob,
Rob,
PUG 306 GTI-6
Rob,
Rob,
I got replacement steering rack yesterday and i can test it before paying. So i today will change that rack and then write some comments. We will also weight wheels once more.. that has been done then 4 times with 2 different weighting machines.
Some good news
My current steering rack was only tightened and that play in the rack is now gone. Wheels were balanced with very good balancing machine, only 5-10g weights / wheel. Steering angles was adjusted too. I think that vibrations are now pretty much gone what i drove yesterday 10kilometres it felt fine. There is still play in the steering wheel axle joint, any ideas where those parts can be bought? Ford sells whole axle and it is not cheap..
Another thing which i noticed there is pretty much play in gear change joints, are there some kind of uprated solution or repair kit available?
You can do a DIY fix on the rod by replacing the bolt that holds the rod in place, its not too difficult to do just make sure the nut and bolt used are good quality either stainless or zinc plated and lock nut.
Matt Baxter
16-09-2015 08:30 PM
Sheepdisease
30-08-2015 09:11 PM
Jack and the Beanstalk
15-08-2015 04:27 PM
