MS and EFI clocks Rev counter wiring
Old Apr 3, 2010 | 03:29 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Default MS and EFI clocks Rev counter wiring
I've tried it direct from the MS ECU and it's not working, so I'm guessing I need to do one of the following....
Seeing as I dont have either to hand thought i'd save some time and ask which one it is?
Cheers!
Old Apr 3, 2010 | 08:20 PM
project rs's Avatar
project rs
yours should work fine if you've got efi clocks just run green wire from rev counter to the coil pack and should be fine mine is that way but as it's a mfi rev counter then it reads half true value till i find some efi clocks to put in it
Old Apr 4, 2010 | 12:19 AM
Karlos G's Avatar
Karlos G
Balls Deep!
It's not mine, it's a mates...
Mine are MFI clocks and they work spot on using a relay to create a high voltage spike, but his are EFI clocks which I thought were low voltage as they run from the ECU not the coil!
Old Apr 4, 2010 | 01:35 AM
mentalasanything's Avatar
mentalasanything
EFi clocks in an EEC-IV environment run from the EDIS. But, they can be run from one side of the coilpack to give the same signal.
Does his car run an EDIS with the MS or does the MS directly drive a ford coilpack?
If so take your feed from one of those and test it. Should work straight out of the tacho output of the MS though as he has EFi clocks.
Lee
Old Apr 4, 2010 | 09:16 AM
Karlos G's Avatar
Karlos G
Balls Deep!
No EDIS, just the coil pack driven direct from the ECU.
So the tacho should work with both high and low voltage inputs? I know MFI clocks need both coil pack sides hooked up or they read 50% less rpm, but EFI ones will read correctly off only one half?
Old Apr 4, 2010 | 11:20 AM
Rick's Avatar
Rick
correct.
Old Apr 4, 2010 | 06:01 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
what i did and is a little more involved, is to take a feed directly off one of the ecu to coil wires and then get megatune/TS on the laptop and see the actual revs, then take clocks out of dash and take apart so you can get to the rev counter adjustment screw, then plug clocks in and adjust till they read correctly.
you'll find the screw under the rev counter with some glue holding it in place.
none of the other methods seemed to work for me or at least seemed more hassle than they are worth.
edit ti say not sure on efi clocks, but the principal should be the same.
Old Apr 4, 2010 | 06:36 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Well, hooked up the EFI clocks to the coil pack and it only reads 50% same as MFI clocks
I'll just use the relay method that I have with my MFI clocks as that will work 100%
Old Sep 10, 2012 | 01:55 AM
A.J_RS.TURBO's Avatar
A.J_RS.TURBO
hi! i have efi clocks but i dont know where to run the green wire...
to the coil Pack but where?
thanks!!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
Mr S1
20
Sep 27, 2015 04:06 PM
