stage 3 t3 or t34 what would be better
what would be a better turbo at around 250bhp .
ive got a stage3 t3 on a autospecialists manifold at the mo.
but have been offered a custom manifold that looks real trick it puts the turbo above the gearbox and is fitted with a t34 turbonectics turbo for a good price.
but would need to sell mine to get it realy.
You won't want to run any serious antilag on your t3 if you want it to last more than 5 minutes really as the heat will kill it, unless you happen to have a maram shafted one?!! My last engine ran a healthy 245bhp on basically a stage 3 t3 at 1.5 bar, ideal for that power level imo without being overly laggy. T34 will have more grunt at the top end if that's your thing but probably not quite as driveable as the t3 in reality.
mine is on a t34 and there is no real lag swapped over from standard turbo to this one and the lag is pretty similar but when it does come in then you really notice it and as when your giving it some stick you always change gear and end up back in power band again so straight to boost but mine is on a tubular manifold and avoid anti lag with what you got
this is why i asked as i have the following spec
gotech mfi and braided loom
power engineering stage 3 big valve head and hi lift cam (but going newman with solid lifters)
arp stud and nut kit with genuine ford head gasket
fully lightened and balanced bottom end and fly wheel
pec steel rods
wozsner low comp forged pistons
acl bearings
custom field motorsport inlet and custom billet fuel rail
dark green 803 injectors
airtech front mount and radiator
airtech breather kit
autospecialists stainless manifold
stage3 t3
ap paddle clutch
so was wondering wether a tubular manifold and t34 would be ok or keep my turbo and manifold
i was thinking about this manifold and turbo as it looks the tits but if it drives like shit then it aint worth it
Guest
Posts: n/a
If the manifold is longer over the gear box set up isn't that creating more lag? As the gass's are taking longer to reach the turbo? Or am i wrong?
As i said the other day and oranoco said anti lag is outta the window unless you wanna throw serious money at a maram shaft!
T3 stage 3 is what's on mine it's quite laggy 3300/3600 she's working hard!
it would seem your t3 stg3 is laggier than my t34 then but i'm of the belief that my ex manny is helping with response but no real proof only it seems to pull well from lower than everyone was expecting
Guest
Posts: n/a
So she's feel's quite quick then boom and your off
A T34 i wanted one too but tbh more money than i have at the min so...
yours is just just a well spec'd engine mate . same as my old cvh and that had a stg3 t3 and full boost by 2600rpm.
Guest
Posts: n/a
http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWAX:IT
i know its ended but this is the manifold and turbo ive been looking at and will come as a complete bolt on package with hoses bleed valve and down pipe ect
i'd save your money and wait till something needs changing as you've got plenty more horses to come first and am not a gold member so can't sell on here just letting people know that i'll have some stuff with me at central
Russ Payne
25-09-2015 08:29 PM
